New 'Safety Feature'
/ New 'Safety Feature' #1
mangus580
Western, NY
Bolens (Iseki) H1502; LS R3039
So yesterday, before I managed to bury the tractor, I was dumping gravel just inside the gate for my cow/goats. The Fiona (the cow) decided to investigate, and was getting in my way as I was coming through the gate. I figured a quick horn toot would encourage her to back away. Well, when I hit the horn button, the engine quit!!
Turns out, every time I hit the horn, the engine dies. Fires right back up... Really odd, huh? This may actually be what caused it to quit the day I thought I ran it out of fuel... Cant recall, but I was pretty sure I tapped the horn then too, to get the kids attention at the window right before it quit.
I will be calling the dealer to have a look see, after I verify it has nothing to do with my added wiring for the Amber Beacon I added to it.
For anyone who is interested....
The dealer came out to look finally (my fault for the delay, not theirs). Turns out its a loose nut behind the wheel!! No, seriously! When I put the ground wire in for my Amber light, I used the same ground source on the right side of the dash thats already there. Well, turns out, that that bolt, is threaded into the firewall, and has a NUT on the other side besides! When I took the bolt out to put my ground in, it came out fine (and it seems it dropped the nut on the ground). This left all 3 grounds on the engine side loose. Randomly they would loose contact, which didnt effect anything except starting sometimes, and using the horn would interfere with the amount of voltage used to hold the run solenoid in place.
Ironically, I had found the nut and wondered what it was for.... so I had it stashed in a pocket someplace. Put it back on, problem solved!
Who woulda thunk?
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
New Holland C232 (A64126)
New Holland C232...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
AGT SAII100 (A64127)
