New receiver
/ New receiver #1
fruitcakesa
CavendishVT
M6040 JD 450C
Welded a 2 inch receiver into the bucket so I could retrieve my trailer that has been languishing in a muddy spot off my tractor trail. I could reach it with the bucket with the tractor mostly on the dryish trail.
/ New receiver #2
I did that!
Does not work well for me.
Even with the tongue jack all the way up, the hitch ball being near the top of the bucket is too high.
Then, using a drop hitch insert instead, puts the ball low, and out of sight from the tractor seat.
I bought a hitch that slips onto one of my forks.
The forks stick way out, so that hitch will work at any coupler height, and can be easily seen from the seat.
/ New receiver #3
I did that!
Even with the tongue jack all the way up the bucket is too high.
Then, using a drop hitch insert, puts the ball completely out of sight from the tractor seat.
There the main reason I haven’t done that. Especially with the yard bucket on the M59. I’ve planned on putting one on my pallet fork frame but I haven’t got around to that.
/ New receiver #4
I did that!
Yep, same here. Too high to be very useful. I ended up buying on that clamps onto the lower lip of the bucket and that does the trick.
/ New receiver #5
I welded the smaller (1.25" ) receiver tube on the bottom of the bucket. Works great for moving trailers and putting boats in the water. It is a little hard to hook up by yourself but you get used to it.
/ New receiver
I figured it would be too high for trailer hauling but useful for other devices that I might want to use , ie; boom pole or hoist.
I don't plan on pulling or pushing the trailer far with it as I have a rear hitch for that.
It really was just a way to get to the mired trailer without going into the mud.
/ New receiver #7
If the OP gets a drop receiver like on the tall 4x4 guys use it should work fine. Might be hard to see to line up but I am sure you will get use to it.
/ New receiver #9
I didn't weld mine just bolted and works great when moving trailer in tight spots. :thumbsup:
/ New receiver #10
You can see that ball from the tractor seat?
Does not appear so in your picture.
/ New receiver #11
No...that the only hiccup about.
/ New receiver #12
I have ball hitches on the back of two trucks, a 4 wheeler, and two tractors. I can't see any of them when backing in to hitch up. That's life. I bet the bucket ball is easier to line up even if you can't see it.
gg
/ New receiver #13
I went a different route, a 3 point hitch receiver and suitcase weight bracket. It's a great counterweight for the loader, and very very handy for moving the trailer around. I can see exactly where the ball is from the tractor seat, put it under the coupler, and raise it into place.
/ New receiver #15
:thumbsup::thumbsup::thumbsup:
View attachment 652703 View attachment 652704
With the clamp on I use a $20 Wyze wireless camera, the wire shown is hooked to one of those small phone chargers.
Makes it REAL easy to hook up.
/edit - I gave up trying to make picture appear upright
6ft Metal Star (A65583)
6ft Metal Star...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
24ft. Folding Harrow (A65640)
24ft. Folding...
3 Point Trailer Mover (A65640)
3 Point Trailer...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
