MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,711
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
To be completely honest with you since it got unloaded right at that spot last week, I haven't even used it yet. Still sitting there. Work has been killin me, I leave the road at 430am and don't get home till 7. By that time I'm completely exhausted. LOL.
I'm sure whichever tilt option I do use will be based off the situation? Maybe Brian can chime in.
Typically, the 3pt tilt will have enough tilt to take care of just about any tilt requirements. But then you could just unplug the side link and plug in the blade tilt.
Actually with the exact setup that you currently have, when using the rear blade, unplug the side link, operate the blade angle with that valve and then use the 3rd valve to operate the blade tilt and offset. So you will need to plumb the blade tilt and offset into the manual diverter.
And of course after you get tired of that manual diverter, (first day of multiple use) then it will be time to get the double diverter system and have the 5 rear remotes that you now need.
