New Pump bad?
/ New Pump bad? #1
Mikeskodiak
Gehl dynalift DP4
I am new to this site. So, not sure if this subject has been beat to death or not? I have a 1999 Gehl Dyna lift DP4 ( an older Lull). The machine was perfect until a few months ago it would work for an hour and it would begin to slow on hydraulic power. Boom up was fine, boom in very slow. squirt out was fine squirt in very slow and then it would stop all controls or so slow it couldn't be used. I replaced all filters and changed all oils. Problem was still the same. I then pulled the hydraulic pump sent to a shop they determined the pump failed. I purchased a new pump installed and still have the same issue? any ideas? I was thinking the torque converter could be bad, however, this thing will crawl in any terrain.
Thank you for the help
/ New Pump bad? #2
I don't know anything about the Dyna Lifts but perhaps the pump is still bad. :(
The first question is how much pressure is it providing the system? In other words, did you do a pressure test? The "squirt test" is not only unreliable but also considerably dangerous--As in fatal or amputation.
It's not uncommon for the cylinders needing to be repacked. Here's a video of one person doing the extension cylinder. Farm Craft.
/ New Pump bad? #3
Could have adjustable relief valves in each spool, check that out.
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
Pat's QH and hydraulic top-link.
Pat's QH and...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
Location (A63116)
Location (A63116)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
