New Post Hold Digger and how do you use yours?
   / New Post Hold Digger and how do you use yours?
I designed a system to modify a 3pt to a hydraulic. Went to Surplus Center and looked up a PTO Motor. Then Came up with a sleeve that would mate the motor to the PHD. Then I designed up a plate to mount the motor to and then the bracket to weld to the frame of the PHD.
End of the day it was the same cost as just going direct drive.
JJ
I did not go for the reversing feature but you are right. I caught a plastic 12" culvert and was jammed up for a moment. Complete panic in my face but then it broke the plastic and all was good with the world.
The controls will be the next step, but I have to convince the wife about the costs. Probably another $200 once I buy the control and the hoses. Not going to happen any time soon.
   / New Post Hold Digger and how do you use yours? #23
El cheapo way to reverse is to switch the hyd QD's.
   / New Post Hold Digger and how do you use yours? #24
I was planning on using my backhoe and thumb control for mine. what motor did you use?
   / New Post Hold Digger and how do you use yours? #25
Today we set gate posts along our driveway. used the PHD to set 6X6 Pressure treated to support a 16 ft tube gate. our road has been built up and rocks go all the way down. it was chunky pulling sometimes.
Learned a lot, like even if you think you are not anywhere near the drain pipe double check, but that being said, I am struggling with something.
The post holes do not come out empty. Our soil is a real mix, but at the end of the day it is pretty good stuff. Not too sandy, not too much clay, very few rocks. But when I dig down no matter what I do (pulling up and out frequently, speeding up) none of it gets me an empty hole. I ended up pulling out the manual post hole digger to get the last foot of loosened dirt out.
Should I expect this or????
Thanks for any advice.
Carl
How about this for a solution.
Wobble Auger | Danuser Machine
Yeah. That is my plan if I get jammed. I made sure I had JIC connectors to the motor so I can swap there. I was told not to remove the QD's once installed as they will leak.
   / New Post Hold Digger and how do you use yours? #29
I get the cleanest hole by doing a spinning up/down, then running the auger to the bottom and stopping it before the final pull-out. The dirt stays on the auger when it's not spinning. I still always have the manual digger handy.
You can see my homemade level (plumb) in this pic. Like 2 letter L's back-back joined at the top. The horizontal parts align when level.
I think most hydraulic skid steer diggers are rigid mounted so the curl function has positive control over the auger angle. Not sure what configuration works best for a PT.
And Brad Wins!!!!!
I knew there had to be a simple way to make a cool level. That is GREAT!!!
Nice property too.
Carl
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
cummins generator (A56857)
cummins generator...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2019 International Bucket Truck (A55973)
2019 International...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
