New PJ dump trailer
/ New PJ dump trailer #1
Steppenwolfe
Super Member
The Blue Ridge Mountains
Kubota MX5400, 1140 RTV
Picking this up tomorrow. 14 K 7 x 16 dump. Figured it will do double duty and haul my tractor back and forth to my son's house when he needs one of my tractors. Also bought a goose neck hitch for my tractor and can haul it around the property. Been on my wish list for awhile...
2 5/16 Inch Gooseneck Coupler, Safety Chains, 2 Drop Leg Jacks, 2 Posi-Lube 7000lb Dexter Brake Drop Axles, 6 Leaf Slipper Spring Suspension, 16 Inch Radial Tires, Electric Breakaway Kit w/Charger, Treadplate Steel Fenders, Front Toolbox, 2 Way Gate (Barn Doors & Spread Gate), 6 Foot 6 Inch Slide In Channel Ramps, 4 D-Rings, 40 Degree Dump Pitch, 12VDC Hydraulic Pump, Scissor Lift, 12 Foot Control Cable, Mounting Brackets for Roll Up Tarp, 8 Inch I-Beam Frame & Tongue, 3 Inch Channel Crossmembers 16 Inch On Center, 10ga Steel Bed, 83 Inch Wide Bed, 10 ga Steel Sides, LED Lights, 24 Inch High Sides, Stake Pockets, Interstate(TM) Deep Cycle Battery, Ultra Low 24 Inch Deck Height, 110V Battery Charger, Integrated 12V Trickle Charger, Sand Blasted, Acid Washed, Powder Coated
Options:
Tarp Kit, 6 D-Rings, 24 Inch Solid Side Extensions
/ New PJ dump trailer #2
I am soooooooo jealous......
Congrats on the new, awesome, well equipped trailer. :)
/ New PJ dump trailer #3
That right there is a nice dump trailer. I'm sure it will serve you well.
I'm jealous too.
/ New PJ dump trailer #4
I've had the 14' version for 6 or 8 years. It's a good trailer but the paint job could be better.
Kim
/ New PJ dump trailer #5
Kim, I've never bought a trailer with paint as a consideration. Have the wheels stayed on?? Has the suspension handled the loads?? Does the dump function work when needed?? Does it pull good?? Do the brakes work adequately for the load carried?? If these are yes, then I could care less about paint. :D
/ New PJ dump trailer #7
Nice trailer.
I looked at some PJ dumps and the paint or powder coat on them did not look like it was professionally applied.
/ New PJ dump trailer #9
Like I said, trailer has been good. Done everything I have needed it to do. Nothing has fallen off, except for some of the paint. Poorly prepped and poorly applied. I guess when it gets bad enough I'll repaint it.
Kim
I quick update , used the new trailer to haul my Kubota for the first time. Pulled fantastic. Going for a load of mulch tomorrow. Can't wait.
/ New PJ dump trailer #11
I have the same trailer. I have loaded it approx 30 times in the past week and was overloaded every time and it still dumps like a champ. I did load it too much a couple of times and had to scoop out some dirt to get it too lift but I am impressed. The day before yesterday we moved 15 loads of moist topsoil that were 5-6 yards each. We put the load toward the back and heap it and leave to front empty so that it is easier to lift. I was worried about the battery going dead by I think it must charge off the pickup.
The day before that we hauled and dumped 5.8 tons of gravel (scaled) with no problems.
I really like it and will probably keep it but we are looking into a dump truck as well. We are getting into moving a lot of material not just for our own projects but for hire. It is raining and we can't do anything now but we have over 200 yards of dirt to move when it dries out. That takes forever five yards at a time.
/ New PJ dump trailer #12
Yeah, I'm pretty sure they are designed to charge from the tow vehicle.
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
832856 (A61166)
832856 (A61166)
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
3142 (A63117)
3142 (A63117)
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
