New Owner / Headlight Trouble CK30
   / New Owner / Headlight Trouble CK30 #11
Hoping someone can help me locate a wiring diagram.
Last night while the tractor is off and parked the high beams come on and stay on. Ran the tractor and the lights went out, everything looks ok so turned it off and went in for the night, 10 minutes later the brights are back on.
Today dug into things, cleaned connectors and such and see that the dash indicator for brights is on all the time. Dash lights aren't on until I turn the head light switch. Seeing that the dash back lights are working as expected I suspect that the light switch is ok. Suspecting the high beam relay is suck on
For now I pulled the fuse.
Anyone else seen this ghost before?
Thanks
   / New Owner / Headlight Trouble CK30 #12
Does yours have brake lights and tail lights? I have seen a couple issues with a bad or corroded brake light bulb back feeding into the headlight circuit causing a similar problem. Just something else you may check.
   / New Owner / Headlight Trouble CK30 #13
gratz on the new CK. give the dealer a call.. 6 yr warranty is nothing to ignore.
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
20ft Driveway Entrance Gate w/ Horse Design (A57454)
20ft Driveway...
Head Gate (A57454)
Head Gate (A57454)
