New Owner / Headlight Trouble CK30
   / New Owner / Headlight Trouble CK30 #11
Hoping someone can help me locate a wiring diagram.
Last night while the tractor is off and parked the high beams come on and stay on. Ran the tractor and the lights went out, everything looks ok so turned it off and went in for the night, 10 minutes later the brights are back on.
Today dug into things, cleaned connectors and such and see that the dash indicator for brights is on all the time. Dash lights aren't on until I turn the head light switch. Seeing that the dash back lights are working as expected I suspect that the light switch is ok. Suspecting the high beam relay is suck on
For now I pulled the fuse.
Anyone else seen this ghost before?
Thanks
   / New Owner / Headlight Trouble CK30 #12
Does yours have brake lights and tail lights? I have seen a couple issues with a bad or corroded brake light bulb back feeding into the headlight circuit causing a similar problem. Just something else you may check.
   / New Owner / Headlight Trouble CK30 #13
gratz on the new CK. give the dealer a call.. 6 yr warranty is nothing to ignore.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
PAZA 3PT SPIN SPREADER (A52708)
PAZA 3PT SPIN...
2019 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
