new or used?
   / new or used? #1
500clunker
west union, west virginia
none yet
Hi all. New to this forum and I joined to ask a particular question. I need a new mower for about 5 acres with some slopes. I can get a new JD x300 for my three grand (thats my limit), or Ive found a 2010 x500 with 100 hrs on it for the same price. The 500 has obviously sat outside, the plastic is all faded and seat is cracked, chute cover is gone, deck rollers are really worn, its obviously had a hard life, plus the warranty is about gone. which would you guys pick? This is killing me. Thanks
   / new or used? #2
Go new! With that you have a dealer and a warranty. Also, it sounds to me like the 500 has been used more than 100 hours. Meter may be disconnected. Good luck with your shopping.:) Also - :welcome: to TBN!
   / new or used? #3
You will want to go as wide as you can, I mow about 3.5 ac, (guess) and it takes over 5 hr with a 4 ft deck running as fast as i can, often flat out foot to the floor. The same place takes 3.5 hr with my massey and a 5 ft deck. I still run as fast as I can. If my educated guess is right and you get a 4' deck you are looking at over 7 hr give or take depending on how many trees ect. you have to mow around. This is a rough guess not chiseled in stone but just something to think about.
   / new or used? #6
Welcome from Ohio :welcome: Go New.
   / new or used? #8
Welcome to TractorByNet!
I moved your thread to the Buying/Pricing/Comparisons forum. :)
   / new or used? #9
If you want to go used I would not limit yourself to the one obviously not well cared for machine. You need to look at other examples of that type and base their value on condition as well as hours. If the machine really has 100 hours and the damage is cosmetic at the right price it could be a buy. Maybe the dealer swapped the deck and it is only the tractor with 100 hours.
Warranties on machines that do not get much use are a bit of an expensive joke. Many exit the covered period without passing the break in period or child mortality problems.
New x500 *$5,199 *and I am not sure if the is prior to or after a $300 rebate.
Unless I am missing something here maybe your dealer needs to work a bit on the x500 used price.
I see 4 or 5 x500's within 200 miles of you at tractorhouse
Last fall I was looking for a new heavy garden tractor but found a 900 hr BX2200 with FEL. I had to drive a day to check it out, it was obvious that it was not well cared for. But all the mechanical stuff worked and it was priced over 2K less then similar tractors most with fewer hours. It was the only BX that came close to my price range so I closed the deal and had it shipped home.
Since then the prices have gone up. Maybe small tractors are a seasonal item worth more in the spring. The spread is now 3K or 4K. So far all the problem have been cosmetic or minor. At 900hrs the engine was not much more then broken in. The rest of the tractor shows its age but with some luck it will outlast me. And instead of having something to polish I have something to tinker with. And a whole lot more tractor. YMMV
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
DESK (A53843)
DESK (A53843)
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
