new mod.
/ new mod. #21
johara1 said:
J.J.,they are 18.2 ci. yes i said they lost a little top end,and i raised the rpm. of the engine but i didn't to it was fast enough for me. they are 340 each with the case drain.........jim
Jim, You may have already done this when you were shopping for hyd motors. If you want a 100% increase, you would look for a hyd motors that has an increase of say 1500 in pounds to a motor that has a rating of 3000 in pounds. A 50% increase would be around 2250 in pounds. To compute the new speed, you have to know the max rpm of the new hyd motors, how much distance the tire travels per minutes, and convert that to mph.
/ new mod.
i think if you read a little more you will find that a case drain is required if the pressure is over 1500 lb........jim
/ new mod. #23
That may be a general rule of thumb, but my mower has a case drain where the tiller and auger do not. They all run on the same PTO on the 1845. The motors run at three different speeds, which may also be a factor in deciding which ones have case drains.
/ new mod. #24
I have to disagree with you on that.
Case Drain Port - Allows use of piston pumps and motors with low pressure case drains.
A case drain is also effective in transferring heat from the motor. I think the case drains from the Pt's that have them, pass through the cooler before going to the tank.
Some say that it is possible to determine the percentage of loss on the motor by the amount of fluid coming out of the case drains. I think you would have to know what the flow was when it was first started, and then compare the original flow with the current flow. Sounds plausible to me.
/ new mod. #25
Johara1,
I am surprised that your PT422 wheel motors has case drains. Mine does not, it uses the white RS series motors. None of my attachments hydraulic motors have case drains either. I've wondered what is the advantage of a case drain, heat removal?
The Char-Lynn motors do look to be 0.54" greater in diameter which you indicated that you took care of by grinding. Some pictures would be great.
/ new mod.
JJ,you can disagree with me, but i feel the charr- lynn factory has the facts you can't dispute.you can even read it on the web site.i worked with morgantown machine&hyd.(the national DIS. for parker) and charr- lynn to find what i wanted.i don't make a statment that isn't backed up by facts.
call the co. and see,also the square back motors used on the older 422 and 425 don't use case drains.if you went my way you would have to add them.i wanted to go with a parker wheel motor but they had no direct replacement so the next move was eaton which had the correct mount.i used the same hub too....jim
/ new mod. #27
duane said:
Johara1,
I called Eaton to ask about case drains. It relieves case pressure and is recommended if you put motors in series (like the PT does). The service guy did not push this hard as I told him that I did not have case drains now. He asked if I was having problems and I said no. The only difference between the case drain model and the no case drain is the case drain hole.
/ new mod.
case drains do many things(1)take any metal out of the motor without going through the rest.(2)cooling effect.(3)they are required on wheelmotors above 1500.also you gain a test port to know the condition of them.
the wheelmotors pt. uses are gerotor type, the s series are geroler,this have a lot more low end torque and start up torque........jim
/ new mod.
i just cut grass for the first time with the new wheel motors.it would cut up a 3 to 1 slope and i didn't even have it wide open. what a improvement! more later,........jim
/ new mod. #30
I've been researching these Char-Lynn S-series motors a bit more, and I'm a bit confused. It seems they only come with 1" splined or 7/8" or 1" straight shafts with a woodruff key -- and no lock nut.
I'd have sworn my wheel motors on my Dec 2000 model 425 have 1.25" tapered shafts with a woodruff key, and a locknut. I'm fairly certain they have a locknut on the wheel hub. Since my PT is in Tennessee and I'm in Mass -- I can't easily confirm that they're 1.25". They certainly have the "serrated type" locknuts, as you can see in this photo.
Flickr Photo Download: IMG_0089
I thought mine came with White 400 series wheel motors also...
Maybe I should try calling Terry to see if he can/will tell me....
/ new mod.
you are right, mine are the old stile that have a 1 inch shaft with a key way.i have a taper lock and a hub that bolt together.....jim
/ new mod. #32
I just talked to Terry in Tazewell. My PT-425, delivered in Dec 2000, has White wheel motors on it -- model number P141X -- and the amazing thing is they're 12ci wheel motors. No wonder this thing doesn't have much torque! :p
His quote to remove these motors, cut off the mounting boxes, drill holes to mount the new-style mounting boxes that bolt on, and then bolt up four new 18 cu in motors came to $2848.60.
Ouch! :eek:
/ new mod. #33
I believe that most all wheel motors have a tapered shaft. Some of the larger wheel motors have 1.5 in tapered shaft.
/ new mod. #34
J_J said:
Do you realize that when you go to a larger wheel motor, the max pressure will decrease. You may have to reset the relief valves for the new pressure rating. Those S-series motors are the 103-xxxx. and they run about $294.00 each. We still don't know the cu in motor you had, and what the new motors cu in . are.
JJ,
If you don't mind me asking, where are you seeing these prices on the S-series motors? The lowest I'm seeing is at Surplus Center -- at $319, as I recall. Then, I'd still have the issue of wheel hubs to deal with...
Thanks!
/ new mod. #35
Kent
If you go to the WHITE HYDRAULICS web site and look at the new WR 255 series motors ( 255-200-F30-10-AAAAA ) 12.3 displacement and compare them to the RS 200 series motors ( 200-200-F30-10-AAAAA ) 12.5 displacement you will find that the new WR series are a perfect match up to the RS motors - mounting holes, 1" shaft, etc. plus you get approx 40% more torque at a higher PSI.(figuring in my head ) for less than $300.00 ea.
/ new mod. #36
KentT said:
JJ,
Thanks!
Try Baileynet.com They have the straight and tapered shaft.
/ new mod. #37
Rivco said:
Kent
Thanks for the tip. If I'm reading the specs correctly those RS motors are VERY low RPM motors. I need something that'll turn in the 80-120RPM range or thereabouts, at ideally 8GPM and 1500PSI.
/ new mod. #38
The OEM motors - 200-200-F30-10-AAAAA spec's: ( PT # P141X12 )
CODE- 200
DISPLACEMENT-12.5
MAX SPEED- cont.(300) inter.(370)
MAX FLOW- cont. (16) inter. (20)
MAX TORQUE- cont. (2640) inter. (3050) stall (2295)
PRESSURE- cont. (1500) inter. (1750) peak (2250)
NEW WR 255 SERIES:255-200-F30-10-AAAAA
CODE- 200
DISPLACEMENT- 12.3
MAX SPEED- cont. (317) inter.(402)
MAX TORQUE- cont. (3850) inter. (4533)
PRESSURE- cont. (2000) INTER. (3000) PEAK (3250)
/ new mod. #39
Rivco, those are max rates, both in RPM, torque and flow. The PT will not produce the maximum GPM flow that the motors will handle, consequently it won't produce those max RPMs.
With that said, I was incorrectly reading the chart -- I confused the flow rate in the table between liters-per-minute and gallons-per-minute. The results are much better, around the 100 RPM range at 8GPM at 1500 PSI. The only remaining challenge is that I need either 1.25" tapered shafts OR new wheel hubs that would fit those smaller 1" shafts.
/ new mod. #40
Do you have 1" straight shafts, 1.25 tapered shafts, or 1.25 straight shafts on your machine??. The # codes I gave you are for ordering with 1" straight shafts. If terry gave you a part # of P141X12 than the RS200-200 series is the motor you have on your machine. The larger PT 425 motors are a P142X14 and have a 1.25 shaft if i'm not mistaken.
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
2022 EZ-GO ELITE...
(3) METAL SINKS (A63291)
(3) METAL SINKS...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
Volvo EC220EL (A60462)
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61574)
2012 23ft...
