New MF GC1723E owner. What next?
   / New MF GC1723E owner. What next? #11
Right -- unless your dealer is very close and handy -- MF parts are $$. I get mine (also for a lower price) from the "local" Kubota dealer -- same pins, as the same company manufactures those blowers (Rad Engineering, Ltd in Canada) for several brands. (Kubota's pins are even the same gold & silver colors....)
One thing I forgot above -- keep some paper towels or rags handy, too -- that blower auger shaft is full of grease and it can get pretty messy when changing shear pins.
   / New MF GC1723E owner. What next? #12
I keep my pins and necessary wrenches and punch to get old pin out in a plastic horror freight ammo box on the tractor with me so I can swap out anywhere, anytime
   / New MF GC1723E owner. What next? #13
Welcome to TBN, keep the tractor greased and have fun with it.
   / New MF GC1723E owner. What next? #14
all my snowblow stuff (I use rear mounted) is within 5 minutes tractor travel to my house. and I my 54" blizzard uses 2 shear bolts and I got approx 15 of each. small jar in shed holding ONLY shear bolts.
but the concept is the same, have a bunch of shear bolts on hand.
I looked closely at dealer cost for the 2 types of shear bolts I use versus buying same size Grade 1 (thats what the bolts are) and there was only (on average) 5 cents difference between buying actual bolt from dealer and a grade 1 at a hardware store. but your experience may not be tha same. just compare prices before buying, may be surprised.
again, mine is rear mounted and I have removable guards over the the 2 shear bolts. average time to swap is 3 minutes for me.
edit: made error stated 3 types of shear bolts, typo, only 2.
   / New MF GC1723E owner. What next? #15
I looked closely at dealer cost for the 3 types of shear bolts I use versus buying same size Grade 1 (thats what the bolts are) and there was only (on average) 5 cents difference between buying actual bolt from dealer and a grade 1 at a hardware store. but your experience may not be tha same. just compare prices before buying, may be surprised.
I'm about the same, rear blower, 2 shear pins. I purchase 100 of each from Bolt Depot - Fastener Shopping Made Easy. I can always get back to the shed quick and the bolts are accessed easily under covers, takes under 5 minutes to change either.
Thanks for all the input folks. Like the lists a couple of you supplied. I'll be well prepared. Definitely see the recurring theme here on the shear pins. Going to find a good local supplier for those ASAP and always carry.
When I said I was a newbie, I mean even my first diesel anything I've owned. So one other question in my mind is will I need some kind of anti-gel fuel additive here in Northern MI? I see that talked about on here once in awhile. Is there a particular brand?
   / New MF GC1723E owner. What next? #17
Mine gelled here in NY. I got some Power Service anti-gel additive and never had a problem since. It's been many years.
Dave
   / New MF GC1723E owner. What next? #18
I keep some Diesel 911 on hand ( in Maine, gets cold) but have never had to use it on the GC2400. but I do start mine often even if not gonna be used and let it get up to operating temp.
   / New MF GC1723E owner. What next? #20
If you are buying it now then you should be safe as you should be getting a winter blend at the moment.
I'm not going to give the most likely answer. I keep 4, 5 gallon cans. I get diesel when 2 are empty and I rotate them. I never know when I bought whatever fuel I'm using at the moment. For this reason I put Power Service in every can before I fill it up. This won't hurt anything and is fine to run all year.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
