New memeber with an old Ford 4000 tractor
   / New memeber with an old Ford 4000 tractor #11
Needed to sign up so I can figure out a solution for a leaking PTO seal.
Classic lack of information. Yes, there could be other things wrong, or it could be leaking elsewhere and not the seal.
Lack of information results in a less than detailed response
Posted symptoms seemed pretty specific to me. Like I said:
"Fact of the matter is, the seal is the same for both 3 And 4 cylinder 4000's and can be changed in place without pulling the shaft or disturbing the bearing/seal housing."
That's how it can be done in 30 minutes regardless of vintage.
This is an 8 speed independent PTO 3 cylinder diesel.
I see oil dripping onto my tow bar that sits right under the PTO. Everything appears to me that the seal is weeping the hydraulic fluid out. I would like to do this job myself and need to find a schematic and part number to order so I can have everything in place.
Thank you for the help.
Ed
BTW I just downloaded the PDF manual somebody posted and am going through it right now. Thank you.
   / New memeber with an old Ford 4000 tractor #14
No problem. I searched hard for that darn manual. Free is always better.
I was thinking about your problem. My grandfather has a TW-15 and it would leak even after a new seal. He ended up buying a new PTO shaft as the dealer recommended it was worn and causing the leak. I helped him put it in last year and surprisingly it has stopped leaking.
   / New memeber with an old Ford 4000 tractor #15
IF you need exploded parts diagrams for anything ford, I like messicks website.
The PTO stuff is under the transmission section
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Club Car Utility Golf Cart (A55853)
Club Car Utility...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
