New memeber with an old Ford 4000 tractor
   / New memeber with an old Ford 4000 tractor #1
edward09603
Royse CIty, Texas
Ford 4000
Needed to sign up so I can figure out a solution for a leaking PTO seal.
   / New memeber with an old Ford 4000 tractor #2
welcome. I know someone will be able to help.
   / New memeber with an old Ford 4000 tractor #3
Welcome to the forum.
   / New memeber with an old Ford 4000 tractor #4
:welcome:
To the forum.
Trying to find a way to stop the leak on a mid 60s Ford 4000 PTO seal. I have some of the paper manuals that I bought, was wondering if the CDs with pictures were better.
Ed
   / New memeber with an old Ford 4000 tractor #7
1st, it would be helpful to know what 4000 you have. 62-65 blue and grey, or 65+ all blue and square profile hood?
As to the leak, there is just a seal and a gasket. Drain oil, remove 4 bolts and pull it out. Replace seal and gasket. 30 minute job.
   / New memeber with an old Ford 4000 tractor #8
A 30 minute job.
Not if it's a 3 cylinder 8 speed 4000 and the thrust washer in the clutch housing drops out of position. That will require some finesse. Fact of the matter is, the seal is the same for both 3 And 4 cylinder 4000's and can be changed in place without pulling the shaft or disturbing the bearing/seal housing. If the shaft has radial or thrust play, more parts and effort will be required.
   / New memeber with an old Ford 4000 tractor #9
Classic lack of information. Yes, there could be other things wrong, or it could be leaking elsewhere and not the seal.
Lack of information results in a less than detailed response
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54756)
LINCOLN ELECTRIC...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
