New memeber with an old Ford 4000 tractor
   / New memeber with an old Ford 4000 tractor #11
Needed to sign up so I can figure out a solution for a leaking PTO seal.
Classic lack of information. Yes, there could be other things wrong, or it could be leaking elsewhere and not the seal.
Lack of information results in a less than detailed response
Posted symptoms seemed pretty specific to me. Like I said:
"Fact of the matter is, the seal is the same for both 3 And 4 cylinder 4000's and can be changed in place without pulling the shaft or disturbing the bearing/seal housing."
That's how it can be done in 30 minutes regardless of vintage.
This is an 8 speed independent PTO 3 cylinder diesel.
I see oil dripping onto my tow bar that sits right under the PTO. Everything appears to me that the seal is weeping the hydraulic fluid out. I would like to do this job myself and need to find a schematic and part number to order so I can have everything in place.
Thank you for the help.
Ed
BTW I just downloaded the PDF manual somebody posted and am going through it right now. Thank you.
   / New memeber with an old Ford 4000 tractor #14
No problem. I searched hard for that darn manual. Free is always better.
I was thinking about your problem. My grandfather has a TW-15 and it would leak even after a new seal. He ended up buying a new PTO shaft as the dealer recommended it was worn and causing the leak. I helped him put it in last year and surprisingly it has stopped leaking.
   / New memeber with an old Ford 4000 tractor #15
IF you need exploded parts diagrams for anything ford, I like messicks website.
The PTO stuff is under the transmission section
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
