new member
   / new member #1
hillbilly53
mellen, wi.
1958 ford powermaster 841
Hello to all, trying to get a 1958 Powermaster up & running. Tractor runs like new, having problems with the hydraulic system. I drained & flushed the case out, rebuilt the hyd pump also. Pump is primed & flows fluid out of the pump but no pressure at pump. No hydraulic lift at all no matter how I move the draft or position levers. Anyone have a suggestion or what to do NEXT?? The tractor had set outside in the weather for a few years without being used or ran.
Thanks
Hillbilly 53
   / new member #2
:welcome: :tractor:
Welcome to the forum!
I'm going to move this thread over to our vintage Ford section to see if we can find you some advice.
   / new member #4
:welcome: to TBN...enjoy.
   / new member #5
HillBilly53- Welcome to TBN!!! And good luck.
   / new member #6
Can't help with the hydraulics but can say :welcome: to the forum.
   / new member #7
Welcome to the forum.
   / new member #8
Thanks
Hillbilly 53
Where are you checking pressure from the pump? If you have fluid coming from the hex bleed screw on the top of the pump, the pump is moving fluid and should be building pressure. Per the attached troubleshooting diagram from the service manual, check the flow control valve. 20190429_210452.jpg20190429_211749.jpg
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
