new member
   / new member #1
hillbilly53
mellen, wi.
1958 ford powermaster 841
Hello to all, trying to get a 1958 Powermaster up & running. Tractor runs like new, having problems with the hydraulic system. I drained & flushed the case out, rebuilt the hyd pump also. Pump is primed & flows fluid out of the pump but no pressure at pump. No hydraulic lift at all no matter how I move the draft or position levers. Anyone have a suggestion or what to do NEXT?? The tractor had set outside in the weather for a few years without being used or ran.
Thanks
Hillbilly 53
   / new member #2
:welcome: :tractor:
Welcome to the forum!
I'm going to move this thread over to our vintage Ford section to see if we can find you some advice.
   / new member #4
:welcome: to TBN...enjoy.
   / new member #5
HillBilly53- Welcome to TBN!!! And good luck.
   / new member #6
Can't help with the hydraulics but can say :welcome: to the forum.
   / new member #7
Welcome to the forum.
   / new member #8
Thanks
Hillbilly 53
Where are you checking pressure from the pump? If you have fluid coming from the hex bleed screw on the top of the pump, the pump is moving fluid and should be building pressure. Per the attached troubleshooting diagram from the service manual, check the flow control valve. 20190429_210452.jpg20190429_211749.jpg
2002 International 9200i Truck (A53473)
2002 International...
FORD F750 XL SUPER DUTY TRUCK (A51406)
FORD F750 XL SUPER...
1992 Ford E-350 Ambulance (A51692)
1992 Ford E-350...
2006 Ford Explorer 4x4 SUV (A51694)
2006 Ford Explorer...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
Light Tower (A52377)
