/ New member #1
jig
On
STX30
I live in Ontario Canada and own a JD STX30 lawn tractor. I am having problems with the starting of this tractor most times I have had to wiggle the battery and it will engage the starter and turn over but it is getting harder to start now. I am hoping someone has a few ideas to help me for correct this problem
/ New member #2
:welcome: to TBN, broken connection or bad ground.
/ New member #3
Welcome:thumbsup:
/ New member #4
Hello & welcome from Iowa.
Sure sounds like a bad connection. Even if a clamp is tight, a post or bolt can be too small to make a good connection. I had to use battery post "covers" (auto parts store) to make a good connection on a Hyundai battery clamp. Take them apart, clean them up, use some corrosion inhibiting electrical grease if necessary. I bet you'll get it fixed.
/ New member #7
Welcome. It sure sounds like a bad connection.
/ New member #8
Welcome toTractorByNet. Check your battery connections. Check with a multimeter while the engine is running to see if the battery is charging.
/ New member
Thanks for the help everything seems to be ok, hope it continues.
/ New member #10
Hello all, I am Mark and i am new here. I have recently join this community to get in touch with the latest information and make discussion on issues related to different topics. Hope to have great relation with users here.
Baby Goat Decorative Statue (A61569)
Baby Goat...
CAT 315F LCR Hydraulic Excavator (A61166)
CAT 315F LCR...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
