/ New member #1
jig
On
STX30
I live in Ontario Canada and own a JD STX30 lawn tractor. I am having problems with the starting of this tractor most times I have had to wiggle the battery and it will engage the starter and turn over but it is getting harder to start now. I am hoping someone has a few ideas to help me for correct this problem
/ New member #2
:welcome: to TBN, broken connection or bad ground.
/ New member #3
Welcome:thumbsup:
/ New member #4
Hello & welcome from Iowa.
Sure sounds like a bad connection. Even if a clamp is tight, a post or bolt can be too small to make a good connection. I had to use battery post "covers" (auto parts store) to make a good connection on a Hyundai battery clamp. Take them apart, clean them up, use some corrosion inhibiting electrical grease if necessary. I bet you'll get it fixed.
/ New member #7
Welcome. It sure sounds like a bad connection.
/ New member #8
Welcome toTractorByNet. Check your battery connections. Check with a multimeter while the engine is running to see if the battery is charging.
/ New member
Thanks for the help everything seems to be ok, hope it continues.
/ New member #10
Hello all, I am Mark and i am new here. I have recently join this community to get in touch with the latest information and make discussion on issues related to different topics. Hope to have great relation with users here.
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
2001 John Deere 6210 (A60462)
2001 John Deere...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61568)
2012 Toyota Tundra...
