New Member
/ New Member #1
GrizzlyAlbert
Mobile, Alabama
Kubota 175
Just joined. Looking for advice on repairing a bush hog. It's leaking oil from underside. I think the brand name is "Razor".
/ New Member #3
Welcome to TBN!!!
I expect you've got a blown seal and you'll probably have to pull the gearbox.
Do you have the manual? If not, determine the manufacturer (I think "Razor" is a model name, not the manufacturer) and see if you can download a manual.
SAFETY!! Block that cutter up so there is absolutely no way if can fall on you!! Even the lighter ones weigh around 600 lbs...maybe not enough to crush you, but it'll prevent you from being able to breath.
/ New Member
Thanks Roy.
Went online to search and I see Razor is a brand made in Georgia. Have not found any sort of assembly info yet.
/ New Member #5
Welcome to TractorByNet from Missouri; what Roy said.:)
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
