New Member
/ New Member #1
GrizzlyAlbert
Mobile, Alabama
Kubota 175
Just joined. Looking for advice on repairing a bush hog. It's leaking oil from underside. I think the brand name is "Razor".
/ New Member #3
Welcome to TBN!!!
I expect you've got a blown seal and you'll probably have to pull the gearbox.
Do you have the manual? If not, determine the manufacturer (I think "Razor" is a model name, not the manufacturer) and see if you can download a manual.
SAFETY!! Block that cutter up so there is absolutely no way if can fall on you!! Even the lighter ones weigh around 600 lbs...maybe not enough to crush you, but it'll prevent you from being able to breath.
/ New Member
Thanks Roy.
Went online to search and I see Razor is a brand made in Georgia. Have not found any sort of assembly info yet.
/ New Member #5
Welcome to TractorByNet from Missouri; what Roy said.:)
GOLF CART FRAME & CAMPER/RV WINOWS & SHELL (A62131)
GOLF CART FRAME &...
UNUSED WOLVERINE CCT-11-148V CONCRETE CHUTER (A62131)
UNUSED WOLVERINE...
207276 (A52708)
207276 (A52708)
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
John Deere 348 Square Baler (A61166)
John Deere 348...
