new member with 750 Deere Problem
   / new member with 750 Deere Problem #1
garyl
750 john deere, 318 john deere,case 580B
Hello, my name is Gary. I have a 750 John Deere 4wd w/Front loader which I have had VERY good luck with,a 318 John Deere w/ Onan ( which I rebuilt after a wristpin keeper came out when it was about ten years old ) and a Case 580B, which I had to rebuild about a month after buying it when the end of the camshaft broke off right behind the gear. My problem right now is that the 750 Deere, which has been pretty good up until now , lost all hydraulic pressure when I started it this morning. I could usually hear the pump as soon as it would start, but today there was no pump sound and no pressure upon starting. I'm hoping that it has a pump key that has sheared. Anyone else gone through this?
   / new member with 750 Deere Problem #2
Hello garyl, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
   / new member with 750 Deere Problem #4
garyl,
I looked through the Technical Manual and there is no keyway. The design utilizes a hex shaft to keep the gear from spinning on the shaft, and is gear driven. I'm guessing the parts are not available individually. Are you certain there is zero hydraulic pressure? I trust the fluid level is normal.
The fluid level is normal. I guess it could be frozen, as it is cold out, but I am not sure what the easiest way to check it would be.That would make the most sense , as it was working fine the day before, but it has been colder and it still worked.
   / new member with 750 Deere Problem #6
garyl,
How about some more background. Your original post only suggests you can not hear the pump and does not have pressure, but did not mention if the 3-pt hitch or FEL work.
Does the tractor have power steering? Some 750 like mine came with PS. If so, is it working?
You could always break open a hydraulic line to see if there is any flow, but you'll need to take the necessary safety precautions when dealing with high pressure fluid.
If there is no flow it could be ice formation on the suction side, but there would likely need to be a fair amount for this to occure. Tractors without PS use a screen, while those with PS will have a filter for the hydraulics. It's simple enough to draing some fluid or take the screen apart to confirm if it is a water issue.
   / new member with 750 Deere Problem #7
Gary, Here are some pics of your pump and drive. Does the pump make any noise at all? Did you hear anything pop or crack when you started the tractor?
GOOD NEWS- 2 bottles of dry gas fixed it right up. It did take a little longer than I expected ( about ten minutes) but it did work. Thanks to everybody who offered assistance
   / new member with 750 Deere Problem #9
Thanks for letting everyone know the outcome and glad to hear it is nothing major.
I am certain you already thought of this, but I'll mention it anyway. Change the fluid and filter (if you have Power Steering) in the near future.
Yep, that is on my list. Went out this morning, fired it up, hydraulics worked great, went about 10 feet , then- fuel line freeze up. Luckily I still had some dry gas left
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
Informational Lot - Shipping (A52128)
Informational Lot...
Quick Attach Pallet Forks (A47384)
Quick Attach...
