New Member w/ 2500a & some questions
   / New Member w/ 2500a & some questions
Re: New Member w/ 2500a & some questions
Yes, for many tractors there is such a valve or adapter to tie in a valve, the problem would be that the valves or adapters to do that are often $300-600 for the valves, or $100-300 for just the adapter (before you get to the valve, or the lines from the valve to the quick connects).
Yes, two work ports for each set of remotes.
Aaron Z
Ok. With a new valve added before the loader valve, would I use the Power Beyond port to connect the new valve to the existing loader valve? Prince's website seems to show that a downstream valve would be connected via PB, but you mention that the outlet would go to the loader valve. Does it matter on an open-center system?
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 132,994 Plate: Body Type... (A56859)
Year: 2014 Make...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
POLY TOTE W/ METAL CAGE & PALLET (A52708)
POLY TOTE W/ METAL...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
