New Member w/ 2500a & some questions
   / New Member w/ 2500a & some questions
Re: New Member w/ 2500a & some questions
Yes, for many tractors there is such a valve or adapter to tie in a valve, the problem would be that the valves or adapters to do that are often $300-600 for the valves, or $100-300 for just the adapter (before you get to the valve, or the lines from the valve to the quick connects).
Yes, two work ports for each set of remotes.
Aaron Z
Ok. With a new valve added before the loader valve, would I use the Power Beyond port to connect the new valve to the existing loader valve? Prince's website seems to show that a downstream valve would be connected via PB, but you mention that the outlet would go to the loader valve. Does it matter on an open-center system?
2015 DRAGON  130BBL VACUUM TRAILER (A58214)
2015 DRAGON...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
1285 (A58374)
1285 (A58374)
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
