New Member, TYM belly mower
   / New Member, TYM belly mower #1
TNTYM
Johnson City, TN
TYM 233 HST
Hello, I am in Johnson City TN. I recently bought a used TYM 233 HST from a private owner with less than 100 hrs, FEL and belly mower $10,000.
The owners manual is lacking information about installing and removing belly mower. Any pointers or techniques for this would be greatly appreciated.
TNTYM
   / New Member, TYM belly mower #2
Welcome to the forum from just up the road. I can't answer your questions but post them in the TYM section and I'm sure someone will have your answer. Good luck.
   / New Member, TYM belly mower #3
Hi and welcome. Wish I was familiar with your tractor. I am sure someone here is.
Good luck with it.
How do I find the "TYM Section?"
   / New Member, TYM belly mower #6
Hi and welcome to TractorByNet! I have moved your thread to the TYM forum where we hope you will find as much useful information as possible. Best of luck!! :thumbsup:
   / New Member, TYM belly mower #7
:welcome:
To the site from Alabama. Glad to see another Vol on this site.
I was able to obtain a full owners manual for my TMB60SH from Dennis at Tractors on the Creek in Fairfield NC - he has been very helpful in learning about my TYM 233 Tractor. http://www.tractorsonthecreek.com/
   / New Member, TYM belly mower #10
I have the belly mower for my t233. It is a pain to take on and off, so much so that i have left it off for a couple seasons now. As far as tips, park the tractor on a hard surface, level concrete or paved is very helpful. The rear deck wheels have a cross drilled hole to rotate them so you can slide it out from the side easier. I used some bailing wire to tie up the deck lift cylinders when the deck is removed. There is very little clearance under the deck even when in the raised position, when you are doing tractor duties you may find it is better to remove the mowing deck or risk damaging it. The shaft of the deck wheels are easy to bend, rotate the brackets so the maximum amount of the shaft is supported. Hope that helps!
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
John Deere X530 (A51573)
John Deere X530...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
New Long Forks (A53002)
New Long Forks...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
