New member - TC40 owner
   / New member - TC40 owner #1
mjozefow
New Holland TC40
I figured I should join up here since I have lurked quite a bit. Here are a few pics of my machine:
   / New member - TC40 owner #2
Welcome to TBN. :)
   / New member - TC40 owner #4
:welcome: mjozefow. It looks like you removed your pin-on bucket for that lift. Nice looking tractor.:thumbsup:
I did. That piece of the drill press was just barely under 2k. I needed all of the purchase I could get.
   / New member - TC40 owner #6
Great tractor. My wife and I love hers. How did it handle the weight and are your tires loaded? That's right at the limits for the 16LA FEL. I am looking at putting a hay grapple on mine that will weigh 1200# - 1500# loaded but will stick out 6'-8' from the QA plate.
It handled it very well, but the load is fairly close in. The tires are not loaded, but it was quite well planted and moved around fine without engaging 4wd, even on grass. Moving my 6' rhino mower with the loader makes the rear wheels really light w/o counterweight.
When the drill base was lifted it just touched the grill guard. So there really was very little lever arm to worry about.
   / New member - TC40 owner #8
Hello & WELCOME to TBN!
I moved your thread to the New Holland Owning/Operating Forum. :)
   / New member - TC40 owner #9
I also have a TC40 which has done all that I have thrown at it but what happened to the bent up and dangling FEL metal hydraulic pipe and hose running under and parallel to the torque bar? It should be anchored alongside the other one in the photo (which is also bent). I can understand some possible trauma to the two upper pipes and hoses but not really to the two under the torque bar. If their purpose is the same as mine, the bent ones control the FEL lift cylinders and obviously you are using the lift in the photos so they aren't cracked or broken-just seems like a weird place for damage.
Welcome aboard.
Welcome aboard.
It is from pushing large (1 car garage sized) piles of brush. Occasionally branches catch funny. The lower hood trim piece has also received some minor battle scars. The tractor vacations with me in North Western Michigan. We go logging for a week or two every year.
I have replaced those lines twice and new ones are on order. This time though I am going to fab up a new guard. :thumbsup: I have not had any actual failures though.
Husqvarna RZ5426 Zero-Turn Lawn Mower (A53117)
Husqvarna RZ5426...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
