New Member needing tractor information.
   / New Member needing tractor information. #1
Barntinkerer
None but looking for one
Just retired from traveling job so built a new barn this year at home in Colorado. Now looking for information for a reliable tractor to put in barn and maintain small acreage. Fill dirt tractor job upcoming with retaining wall which will need retaining wall and post. Any advise on small reliable tractor types to consider appreciated.
Thanks all,
   / New Member needing tractor information. #2
Hello Barntinkerer, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
   / New Member needing tractor information. #3
:welcome:
Many tractors will do what you want and be reliable.
I'd recommend visiting a local dealer who you know or who is known by a friend. Someone you can work with and has been in business for awhile (prolly a reason for that). Go with the brand the dealer will support.
My take would be a tractor in the 35 hp range.
I've a JD 4300 12 years old, and wouldn't want less in size nor feel real compelled to increase its size. Have 20 some acres and use it with FEL, forks, bucket, rotary cutter, tiller, logging, snow removal, etc. etc. etc. :)
   / New Member needing tractor information. #4
hi i would get a kubota l3400 or a kubota l2800 they are not too big but not to small.
   / New Member needing tractor information. #6
Welcome Barntinkerer.:thumbsup:
That statement pretty well cover's it.:)
   / New Member needing tractor information. #8
MF has a great line of cuts. Might look at the MF1645 that's a good size tractor for what u would be wanting to do.
   / New Member needing tractor information. #9
Welcome to TBN!!
OLIVER DAHLMAN LOT NUMBER 248 (A53084)
OLIVER DAHLMAN LOT...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
