New Member kioti ck hydro
   / New Member kioti ck hydro #1
johnpenny
Hello I bought a kioti ck 20. The control pedal will not engage unless you put a lot of pressure on it. Any ideahs what may be wrong. Also looking for parts such as the rear lights thank you john
   / New Member kioti ck hydro #2
Are you talking hydro pedal or throttle pedal? I had a problem with my throttle pedal. Traced it to binding where it feeds through the wall to the engine compartment. Loosened up the feed through and readjusted. The lubed it real good. It's been perfect ever since.
HST pedal, can't help. I have gear. But likely is a linkage bind up under neath. Probably just needs lube and use.
   / New Member kioti ck hydro #3
I believe there was a recall on this and would likely be replaced by dealer at no cost
   / New Member kioti ck hydro #5
To my knowledge, the ck20 doesn't have a throttle pedal, just the lever on the instrument panel. I assumed he was referring to the hydro-stat pedal....
   / New Member kioti ck hydro #6
If it's the hydro pedal, then the problem is usually at the shaft through the transmission case or the damper assembly. In either case, a good cleaning and lubing does the trick. As previously posted, make sure you get a good penetrating oil on the shaft at the case, and some white grease on the damper shaft.
Let us know if there are parts you need.
   / New Member kioti ck hydro #7
If you are in high range you will get the same effect
Thanks For all the help will look at it tomorrow and see what it may be. The tractor has spent a lot of time just sitting in the barnso i am going to go throug it and see what else is needed.
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
