New Member kioti ck hydro
   / New Member kioti ck hydro #1
johnpenny
Hello I bought a kioti ck 20. The control pedal will not engage unless you put a lot of pressure on it. Any ideahs what may be wrong. Also looking for parts such as the rear lights thank you john
   / New Member kioti ck hydro #2
Are you talking hydro pedal or throttle pedal? I had a problem with my throttle pedal. Traced it to binding where it feeds through the wall to the engine compartment. Loosened up the feed through and readjusted. The lubed it real good. It's been perfect ever since.
HST pedal, can't help. I have gear. But likely is a linkage bind up under neath. Probably just needs lube and use.
   / New Member kioti ck hydro #3
I believe there was a recall on this and would likely be replaced by dealer at no cost
   / New Member kioti ck hydro #5
To my knowledge, the ck20 doesn't have a throttle pedal, just the lever on the instrument panel. I assumed he was referring to the hydro-stat pedal....
   / New Member kioti ck hydro #6
If it's the hydro pedal, then the problem is usually at the shaft through the transmission case or the damper assembly. In either case, a good cleaning and lubing does the trick. As previously posted, make sure you get a good penetrating oil on the shaft at the case, and some white grease on the damper shaft.
Let us know if there are parts you need.
   / New Member kioti ck hydro #7
If you are in high range you will get the same effect
Thanks For all the help will look at it tomorrow and see what it may be. The tractor has spent a lot of time just sitting in the barnso i am going to go throug it and see what else is needed.
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
