New Member John Deere 855
   / New Member John Deere 855 #1
tab108
Tallahassee, FL
John Deere 855
Just bought a JD 855 that had been sitting for several years. It is 4wd and has a 70A loader. Just changed the oil. Hydro fluid looks good. Cleaned the air filters.
Problems:
4x4 does not work (shaft turns, but not the frontend, oild drained and no metal found)
hydro forward and reverse pedals hard to push
throttle lever falls down and you have to keep pushing it up
three point hitch lever falls down and have to hold it up
hydro control for loader works for up and down, but tilting the bucket gives me problems, sometimes works, sometimes not (linkage issue?)
Any ideas?
   / New Member John Deere 855 #2
Welcome to TBN. :)
   / New Member John Deere 855 #4
There is a specific Hydraulics forum here on TBN. Perhaps you might get some answers by reviewing that section and posting your inquiry there? BTW, Welcome aboard and Good Luck.
   / New Member John Deere 855 #5
WELCOME to TBN :)
I moved your thread to the John Deere Owning/Operating Forum.
   / New Member John Deere 855 #6
The 855's front axle has a dubious history of wiping all the teeth off the pinion gear and/or shearing the bolts that attach the ring gear to the differential carrier.
   / New Member John Deere 855 #7
No, A John Deere with front end troubles? Can't be
   / New Member John Deere 855 #8
Tighten the throttle lever pivot bolt, there should be a set of friction washers to tighten against it. The pedals on those are stiff to push. I would be worried if you said otherwise. The front drivshaft will turn any time the tractor is moving because it is direct linked to to the shafts and tires. The question is weather it turns with power. Raise up all four tires and test drive with it engaged and disengaged. Then see if the shaft still turns. The linkages on the joystick get kinda screwy at times.
   / New Member John Deere 855 #9
Could also be the same problem for the three point lever moving as the throttle lever.
   / New Member John Deere 855 #10
Check the hydraulic quick connections. They should be fully engaged. Make sure to have the loader buckt on the ground and not residual pressue in the lines (tractor off, wiggle the lever in all directions to relieve pressure). These quick connections are notorious, but an easy fix.
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
