new member 2520 starting question
   / new member 2520 starting question #11
Hiya,
The "start at 1/2 throttle" is a common generic Diesel starting procedure. I checked my manuals for Cummins and Detroit engines and they are just the same. I start all my Diesels with the throttle at idle or with a very slight opening. (the over the road trucks seem to like just a touch of throttle)
I was told many years ago by a Diesel wrench tech that the open throttle startup was for the old Detroit 53 and 71 series with roots superchargers. He said that the engines depended on boost to light off the rest of the cylinders when cold and the easiest way to do that was to have RPM's as soon as one fired.
Tom
   / new member 2520 starting question #13
"(1)I always start mine at idle, and there's just an initial puff of smoke which clears away within seconds."
Same here, and no problems starting so far. I must admit the only reason I started doing it that way is because you are told not to apply throttle when starting vehicles with fuel injection, so I assumed a fuel injected tractor would be the same.
JD2520, I'm just curious if you've ever tried starting yours at idle setting, and, if so, do you still have lots of smoke?
not as much
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
SARLO MOWER (A55758)
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2021 CATERPILLAR 908M WHEEL LOADER (A52705)
2021 CATERPILLAR...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
2007 Kenworth T300 Fuel and Lube Truck (A55788)
2007 Kenworth T300...
