New Max series...
   / New Max series... #201
If you say so..........I also have a subcut. My tiller was made for a subcut. My cultivator is a full cat 1, and will drag the ground if I hit a slight bump.
That is the difference between cut and subcut..........and you know this. You are not a newbie here.
But I did notice that you list no bx in your sig line, and I haven't seen a BX CUT before...........build it yourself?
You forgot your tagline!! Mahindra does not make a SCUT! Please be consistent. Your credibility has dropped form poor to SUB-poor.:laughing:
   / New Max series... #204
I did this to help you see better.
   / New Max series... #205
Is there a 54" roll over MMM for the Max 22 or 25? The land I have is pretty uneven and anything larger than that will scrape the ground. Also, I understand that you can add a backhoe anytime to the Max. Is this true? Being a tractor newb, I don't see why they would need to state this. Do backhoes require some specific hardware not normally installed on the tractor when first purchased?
   / New Max series... #206
Only SCUT with a drive over deck is the Deere 1 series.
The reason they say you can add a backhoe at any time is because on Kubota's you have to get the BX25 to get a backhoe. The other models do not have an option for a backhoe. With this, you will still have to get a subframe and certain hydraulics before installing the backhoe on a Max, but you can't do that with the Kubota. In short, if you want a backhoe on a Kubota, you have to get it from the factory, the other SCUTs will allow you to add it afterward.
   / New Max series... #207
There is a 60 & 62" roll over MMM.
   / New Max series... #208
This thread has became quite... entertaining. :laughing:
   / New Max series... #209
Virtually any deck can be driven over. I drive over mine sometimes, but usually just park the tractor on the downhill side and drag it under.
larry
   / New Max series... #210
The MMM for the Max is a drive-over deck. But I haven't personally used one yet, so I can't give any first hand details regarding ease of installation or anything like that. When I get a chance I'll check one out and report back. But I do see that our sales info shows drive-over.
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
Golf cart (A56859)
Golf cart (A56859)
KBH 25 TON TENDER (A56435)
KBH 25 TON TENDER...
TANK MANIFOLD (A55745)
