New M9000 has arrived
/ New M9000 has arrived #1
toy1
Goshen, CT.
kobota KX 080-3,R630, KX121-3, L48, L4630, bx23, cat257, M9000,(3) RTV1100,jd450h, ASV100 ,zd331,
Well my new m9000 has arrived. I ordered it last Oct and said to my dealer I would like it toward the end of March. Feb came and he called me that the m9000 would not arrive untill the end of June so he got one from a dealer down south. First impressions are nice machine,alot of power. Not as user frendly as the L48 from the ability to creep and change direction but much better when work long stretches in the field.I will try to get some lower resolutions pictures to post.
/ New M9000 has arrived #2
Congratulations Carl
I’m sure you will be happy with the performance of this tractor. When I got my M9000 a couple of years ago there really weren’t any other M9000 owners on TBN. Most the folks with utility tractors had NH TN’s. Now that’s changing. There has been lots of discussions about the M9000 lately. That’s great for us.
I was curious what kinds of jobs and attachments you were going to be using with this tractor? I use mine for cleaning my poultry barns with my barn cleaning machine, flail mower, tiller, and leveler that I use for leveling out the litter in my chicken barns. This weekend I was pulling my leveler blade in 3rd gear high range. I pulled so much the tractor stopped and all four wheels were still spinning in the soft litter. That’s power.
Eric
I will be using the M9000 for general work on the farm.I will be Cutting hay this year and will start clearing 20 more acres. I will be planting 2000 blueberry plants this year and have alot of ground prep.I have a Patu 175 wood chipper that will be on M9000 it will be much better then on the L48.the M9000 has quick hitch from Ati with a 84" bucket I can use all of the attachment from my Cat257 on the M9000. I have front remote hyd., puts out about 19.3 gallons on the M9000.
/ New M9000 has arrived #4
<font color="blue"> When I got my M9000 a couple of years ago there really weren’t any other M9000 owners on TBN. </font>
But there was a Kubota M8950 owner!
Carl, I hope you enjoy your new tractor.
/ New M9000 has arrived #5
Your right. How could I forget about Gatorboy and your mowers?
Carl
Thats great you got the ATI attachment plate. Did your dealer build your loader with the quick attach or did you have to add a this quick attach to the kubota quick attach? Was it much extra?
If you have a digital camera I would like to check out this set up.
Eric
When I ordered it, I ordered it with the Quick attach. However Kubota does not offer it yet even though their price guide said it is available. I think My dealer said you can get it from Kubota but cannot get 84 inch. bucket, it is available with 79 inch bucket which is a little shy of the tread width.So he charged me the same price as if it came with the kubota set up and 79 inch. bucket. I will try to take some low resolution photos tonight if it isn't raining.The nice part is the front Hyd. it has a switch on the loader lever that allows you to engage the hyd. I am going to have one installed on my L48 soon.
here are some pictures
ATI bucket
front remote Hyd
control for front remote is a switch on top of handle. The black plastic piece slips over the loader control stick makes for a nice setup.
/ New M9000 has arrived #11
Wow Carl
You really set that tractor up perfect. The ATI quick attach looks really heavy duty and the flush face hydraulic fittings are a great. I’m sure it’s nice to be able to switch tools between the skid steer and the tractor. I’m going to have to show my wife your setup because when I get ready to go with a loader I will set it up exactly the same. I could really build a huge manure bucket for it.
Thanks for sharing.
Eric
/ New M9000 has arrived #12
Very nice machine toy1! I have a M9000 HDC3 myself I really like. Mine was delivered in late December and I have about 50 hrs on it. Like 40Kchicks says, some power.
I am currently building a grapple for mine (fun project) and have been planning a front Hyd setup like you have. I really like your flat face valve placement. Where did you get the slip over handle for your joystick? After reading feedback from Pineridge and Jinman, I think this is the way to go for controlling the grapple.
Thanks.
/ New M9000 has arrived #13
I too would appreciate info on the slip over handle for your grapple button. I have an ATI 4n1 bucket with Fassi brand controls for it. Fassi's button is Ty-wrapped onto the joystick shaft. Beside looking pretty bad it is hard to use comfortably. Any info on top mounted buttons will be appreciated.
the valve kit and over the handle control comes from W R Long the web site is wrlonginc.com. Look under valve kit.
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2020 Case TV370B (A64126)
2020 Case TV370B...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
Steiner 450 (A64126)
