New M7040 low brake pedal
   / New M7040 low brake pedal #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My neighbor has a new M7040 DTC and is temporarily laid up so I did his 50 hour service today. All went OK except I noticed the brake pedal went nearly to the floor. I had a friend go to a dealer to check a different M7040 and he said that pedal felt pretty low as well.
Anyone else with an M7040 with a really low brake pedal? How low--or high-- is your pedal? This one goes almost to the floor and did it since it was new.
   / New M7040 low brake pedal #2
If it stops the tractor, that is - the brakes work, it is probably not too serious. Just watch it.
It nearly bottoms out--maybe another half inch or so.
   / New M7040 low brake pedal #4
Mine travels quite a bit also. When you put on the brake lock does it lock on the first or second detent? As you push down on the brake hold the brake lock forward and you can feel the detents.
There is probably an adjustment somewhere that can be done. Just follow the linkage under the floorboard until a turnbuckle or something shows up.
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
(2) Pallets of Implement Parts (A50121)
(2) Pallets of...
