New LX410
/ New LX410 #1
jblx410
Purvis, MS
Ha mar LX410
I'm sitting here waiting for my new LX410 to be delivered. New to the forum. Wish me luck!😬
/ New LX410 #2
:welcome:
Tot he forum from Alabama. You don't need luck, Just familiarize yourself with all the safety features, ensure all the fluids are correct and go have fun. Be sure to perform all the required maintenance when they are due. Congrats on the new little Cubbie.
/ New LX410 #3
Congrats on your new purchase and Welcome to TBN and the new Yanmar club!
/ New LX410 #4
Great Choice! The LX410 is an excellent tractor. You will be impressed!
/ New LX410 #6
My 410 is going on 3 years old now, still great as ever.
But then I've been a Yanmar fan since I owned a 220D from 1985-1998.
Between 1998 and 2012, I had the unfortunate experience of owning a New Holland 1925.....not NEAR the tractor Yanmar builds.
One thing you might want to do: Add the step to the right side if yours didn't come with it (mine didn't). I found it quite unhandy to always have to get off on the left side and walk around the tractor if something needs doing on the right side.
I also welded a pc of angle between the ROPS behind the seat to mount a decent sized tool box. The one that comes in the fender doesn't hold enough tools to suit me.
/ New LX410 #7
You should be pleasantly surprised at how little the step costs, I don't remember exactly but somewhere around $14 dollars. I had to drill a couple of holes to mount mine but well worth the trouble.
/ New LX410 #8
This is an old thread, so not sure anyone's still listening, but... where did you get the right side step? That is a pain to keep going all the way around, or take that big step upward.
Also - anyone have a wiring diagram for the Lx410? I can't seem to find a specific service manual for it, and I'm chasing down a repeated blown Switch Fuse. No obvious signs of frayed or chewed wires, it just keeps popping.
/ New LX410 #9
I installed a step on the right side.....just bought the left side step, requires some cutting and mods, but easy enuff and works great. Step was quite reasonably priced as well. Good luck.
/ New LX410 #10
I also used the left side step...just turn it around and mount on the right side. Been a while, but I don't recall having to do anything but bolt it up. If I recall, the mount tabs for the step are already there....which begs the question: WHY didn't Yanmar put one on it to start with ?
I also added a fender handle on the right side....I like something to hold on to lot of time bushhogging or whatever. Just bought another handle and drilled the fender, bolted on.
/ New LX410 #11
Possibly a bit different from mine cause I've got a lx4900, and the front aux valve is located right there....
/ New LX410 #12
I have this for the EX450, wondering if its similar. Same engine, same age, same size, etc.
/ New LX410 #13
This helps a lot - thanks!
Where did you get these diagrams? I've been looking for where I could buy something like these.
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
6' 3Pt Disk (A66285)
