jd4310man
- Joined
- Mar 8, 2006
- Messages
- 206
- Location
- Scottdale, PA
- Tractor
- Yanmar VIO27-3, New Holland LX885, John Deere 855 C.U.T.
Just got done with a new valve installation on my loader. Im using the 10 gpm Brand LV series loader valve that uses one control stick to operate two spools. it has float position and regen mode. I installed a power beyond plug to feed an auxiliary valve down stream. All lines to loader are correctly connected, flow from pump comes in to the new valve and exits out threw the power beyond. It then feeds the aux valve downstream. I also installed a bypass hose to the return line as per instructions. My problem is the loader will raise normal but lowering it puts a load on the engine. The bucket also will put a load when moving in either direction. There is no load on loader to cause a strain to the engine, but from just moving it back and forth, it is causing a buildup of pressure when there is no load on hydraulics. The speed is not very fast so I don't think its because of too much flow, although im not exactly sure as im using a flow divider that is preset from factory. Any ideas what would cause this strain on the system with no load on system?
