New linkage for 1450 loader
/ New linkage for 1450 loader #1
DK35vince
Super Member
western,pa.
Kioti DK 35
I have pictures of my new loader linkage, which I like better than my original design
Here is a picture of my first set( didn't like this design). They were to long and not enough curve at the lower half
Moving the pins up 3" seemed to help some.
I can now roll back a full bucket, which is more than I could do before.
I now have more clearance to get full throw from my tilt cylinders than my original attempt..
/ New linkage for 1450 loader #5
Great Vince! That sure looks like a nice job you did on that, and now you won't have to be so frustrated with roll back and dump. Thanks for posting the pics as I was wondering how that was going. John
/ New linkage for 1450 loader #6
Vince, I was wondering if this helped the amount of curl, the power of the curl or both.
It is interesting the the things you have done.
Thanks, KO
My roll back angle is the same.
I lost a little bit of dump angle.( not enough to effect me)
I seemed to have gained some curl power. Which is where I needed the gain.
Kiohio,
I could have easily made the linkage for more curl angle by just moving the very top pin back farther when making the linkage.
But I would have lost a little more dump angle by doing so.
So I tryed to maintain my original roll back angle and get a little more leverage for curl power.
/ New linkage for 1450 loader #9
Does it still come far enough back that at full height and full dump it achieves enough that the edge is past the 90 degree point? At least an inch or so.
As long as that is still achieved I wouldn't think anyone would have a problem with it.
I was thinking your main goal was curl power.
Thanks, KO
I'll try to remember to check that out tomorrow evening to be sure and get back to you on that one.
/ New linkage for 1450 loader #11
That looks good. Your bucket bracket is different than mine. Did you modify that as well?? Mine is more of a triangle with not as much room to move around at the top. Now please give the distances you have those 3 holes apart and the thickness of the metal. Thanks bcs
At full height and full dump my bucket edge is close to 6" lower than the rear of the bucket. So I should be fine.
</font><font color="blue" class="small">( Your bucket bracket is different than mine. Did you modify that as well?? )</font>
No, I have the skid steer style quick attach that my pins go to instead of the bucket.
The linkage is 5/16" steel
The bucket pins are 3" higher
For the linkage, the lower 2 holes and linkage is the same with the very top (3rd pin ) 3" higher.
I needed to buy 2 pins Part#0550-3013
2 dust covers Part#0541-3002
2 O-rings Part#0520-3000
2 bolts Part#0545-2024
You will also need to add new curl and dump bucket stops
