New land... need a tractor!!
   / New land... need a tractor!! #251
Perhaps you meant 25%? That's 1 in 4 or about 14deg. MUCH more manageable with a big CUT.
25deg is closer to 1:2. That's a one foot rise for every 2 horizontal feet.
25% still feels pretty steep especially on a tractor...
Yeah, maybe it's 25% not 25 degrees. My dozer operator told me 2 months ago or so & I know he said 25(something?). Regardless, with all the rocks on the steepest parts I need to know what the most stable option would be. In comparing the older tractors (4K+ lbs., which is what I grew up bush hogging with on flat farm land NOT on steep property) to the majority of 2000 year models & up tractors have 4x4 but only weigh +/-2,000 lbs. & a lot of them have front tires that look to be very small.
   / New land... need a tractor!! #252
I honestly don't see any 25 degree slopes in the photos. Looks pretty much like the hill I mow which I measure as about 12-13 degrees with an inclinometer. That said, my sphincter meter goes off at about 10 degrees on a slope with hard to see holes and bumps. I simply mow up and down which simplifies matters greatly and allows faster and safer speeds.
If I really needed to mow 25 degree slopes, I'd get an articulated tractor rather than a big CUT. Having said that, I wouldn't hesitate to mow the land in your photos with my Kioti DK40se which is just a bit bigger than the Mahindra you listed and smaller than the Allis.
You do have a lot of rocks! Must be in the northeast if I remember my geography. Those pictures could pass for New Hampshire or Massachusetts given all the rocks.
Island tractor,
is your Kioti 2x4 or 4x4?
   / New land... need a tractor!! #253
Remember, weight is important for traction but center of gravity is what largely determines rollover point (along with pivot point- why wider is better). So I'm not sure curb weight tells you much.
You can and will add weight down low by ballasting tires, adding wheel weights and buying heavy 3pt equipment.
You will improve pivot point by changing how you operate the machine (when not to side slope/turn/front wheels that can turn/etc) and by widening the wheels (aftermarket spacers or hubs/rims that are adjustable).
Since you are looking at used tractors, I would post some pictures of potential tractors and let some of the more experienced guys on here comments on which has the better COG.
A cabbed 10,000 pound utility tractor with big ag tires (high profile) will have a much higher COG and be easier to roll than a Large 5,000 pound open-station CUT with R4 tires. IMO.
   / New land... need a tractor!! #254
BTW, pictures can be very deceiving but all of that looks mowable with my setup too.
   / New land... need a tractor!! #256
Here's some pictures: 1. Agco Allis 5650 48hp 4x4 w/loader Agco Allis 5650 4x4 48hp loader bushhog.jpg , 2. Belarus 825 100hp 4x4 loader Belarus 825 4x4 100 hp.jpg , 3. Yanmar YM3110 loader 2x4 40hp 80's model Yanmar YM3110 4x4 loader 37hp.jpg , 4. 2010 Mahindra 3316 4x4 hydrostatic loader & backhoe attachment Mahindra 3316 4x4 with backhoe & loader.jpg Mahindra 3316 Backhoe Attachment.jpg , 5. Belarus 250AS 2x4 bushhog Belarus 250AS with bushhog 2x4.jpg , 6. 1996 Massey 253 loader 2x4 1996 Massey 253 loader 2x4.jpg , 7. Kubota L3000 4x4 loader 35hp 185hrs Kubota L3000 4x4 loader 32hp.jpg , 8. Ford 4000 2x4 loader Ford 4000 loader 2x4.jpg .
These are some I've found within driving distance that I am considering. But again, I am open to suggestions based on lower COG, wheel width, HP, 4x4, loader, etc... i'm not opposed to looking at newer used tractors but have looked & all I see is subcompact (1,000-2,500 lbs.) and I, knowing nothing about them would think they would be more likely to tip/flip than a heavier tractor but maybe I'm just use to driving an old Ford 4000 that weighs a ton!
What tractor manufacturer & model offers the lowest COG & widest stance in 4x4 that allow for widening the wheels (aftermarket spacers or hubs/rims that are adjustable)?
   / New land... need a tractor!! #257
I would suggest 4x4 if intending to use an FEL.
I would seriously investigate parts/dealership availability if buying used.
CNH offers one of the most comprehensive parts availability system out there. Great internet support. Easy ordering.
Kubota also offers good support with easy online ordering.
Just understand that whatever brand of tractor you buy is going to require parts eventually.
   / New land... need a tractor!! #258
For stability, for a given tractor, nothing beats a wide stance. Many rear wheels are reversible, or if not, spacers could be available. For example, the rears on my L3400 Kubota are not reversible, but with 1.75" spacers, things are greatly improved. P1010765.jpg That, and keeping any loader weight LOW when traveling.
   / New land... need a tractor!! #259
I am REALLY needing some assistance as soon as possible because I need to purchase a tractor so, I can get the property ready to seed as soon as possible! What tractor manufacturer & model offers the lowest COG & widest stance in 4x4 that allow for widening the wheels (aftermarket spacers or hubs/rims that are adjustable)? Please refer to my previous posts with pics of the property & pics of the tractors I'm currently looking at. Thanks
   / New land... need a tractor!! #260
The reason you haven't gotten many specific replies is that most CUTs of a given size are pretty equivalent with regard to COG and wheel distance. Wheel spacers are probably more easily obtained for JD and Kubota based on volume but you'll find that other brands often use Kubota or JD standards on wheels anyways.
Most of us wouldn't buy a compact utility tractor based on COG as the major determinant. Get a good tractor and set it up with appropriate ballast and maybe spacers. Then do your work up and down the hilly bits instead of across the slope.
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
MCELROY 500 SERIES 3 TRACKED FUSION MACHINE (A50854)
MCELROY 500 SERIES...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
