New L5240 Starting Rough
   / New L5240 Starting Rough
Thanks for all the feedback!
I emailed a link to the video to Kubota. I'm not counting on a reply but you never know.
Someone asked about the glow plugs and I did wait for the glow plug light to go out before starting. I have also tried turning the key on and off several times and still had the same result.
I will keep you posted.
   / New L5240 Starting Rough #22
Mine does this also? I have not tried half throttle yet but will next time I start it. If your glow plug light goes out , Does it mean you glow plugs are working? If not , How does one prove they are functional? Have not had my new tractor during cold weather yet.
Thanks-
   / New L5240 Starting Rough #23
Thanks-
If you have a volt meter clamp the positive to one of the glow plugs and ground the other to the engine block. Then cycle the gp's and you should see somewhere bewteen 10-12 volts.:)
I also cycled my several times and it made no difference. I am 'almost' convinced that it is this way because of the emissions junk they put on it.:mad:
   / New L5240 Starting Rough #24
Your starts look just like mine do on my new L5740. Having been involved with engine applications for 27 to 175 HP powered equipment for a major construction equipment manufacturer, I don't see anything unusual. The Tier 4 interim small engines (less than 75) allow a lot of soot emissions. Our FADEC engines ( FADEC = Full Authority Digital Engine Control) are a lot cleaner but we don't use them on small diesels because we can meet the emissions without the expense. So you have indirect injection which tends to be dirtier, and a turbo that has not yet spooled up providing the oxygen needed for clean combusion, you're going to get smoke. I know it makes me shudder to think of what high engine speed cold starts mean to component life but our Tier 1 engines (before FADEC) required high idle starts to meet emissions, then throttle down once the engine is running smoothly. I don't know if anybody read the manual and started using the book method (I rarely did except for specific start testing - seeing how high pressures spike with high speeds and cold oil) but I reviewed all warranty and never saw any increased claims vs. the previous engine with the same power train. Yes, I like how my JD7730 starts compared to my L5740 but 152 HP with all the bells and whistles cost more than triple what my CUT L5740 cost - but after 14 hours a day on that air ride seat you get to thinking it is worth every penny.
   / New L5240 Starting Rough #25
Almost forgot, if you are interested in what the white smoke from a blown head gasket looks like, this is an engine running at low idle 2 minutes after start. It is a larger engine, a 4.4 liter 130 HP mechanical fuel injection engine.
Here is the reply from Kubota:
Good afternoon,
I am the Division Service Manager for Kubota based in our Fort Worth, TX
office. Your email and video have been forwarded to me for a response. I
have viewed the videos you supplied, and offer the following observations /
comments:
1. At a cold start, the initial puff of smoke appears to be black followed
by white.
2. Within 3-5 seconds this clears up and the tractor exhaust shows no
visible sign of smoke.
3. I assume there are no other concerns or symptoms such as lack of power,
or missing under load.
4. I also assume the elevation where you are located is 4000-5000 feet
above sea level. (We are at 7600 feet)
5.Your tractor is equipped with a Kubota diesel engine that is Interim
Tier-4 certified for exhaust emissions.
Considering the above, it is my opinion that the initial smoke and
"stumbling" the engine is experiencing, is consistent with the performance
of an Interim Tier-4 certified engine.
Your altitude will also have an impact during initial cold start up. But
since this is a turbocharged engine, once the engine is started, the
turbocharger is functional and altitude should not be a major factor
when operating in the field.
Thank you for purchasing Kubota products.
Dave Haggerty
Central Division Service Manager
14855 FAA Blvd. Fort Worth, TX 76155
I guess that is how is should run. Now I just have to remember to not start the tractor in the barn when my wife is milking. :smiley_aafz:
Thanks for all the great feedback!
   / New L5240 Starting Rough #27
Good afternoon,
comments:
by white.
Dave Haggerty
Interesting but not very informative. My B3200 is I-4 too and has none of the white smoke after the initial black puff. But I think this is how these engines are going to be. No big deal just annoying.
Nifty how a low emission engine smokes more than an old :laughing::laughing::confused2::confused2:eek:ne.:laughing::laughing::confused2:
   / New L5240 Starting Rough #28
When my L5030 goes toes up, I may look for a good used L5240/5740 with the older emissions system.
   / New L5240 Starting Rough #30
Did they ever make them without the EGR?
I honestly don't know, but we have a 60's model Case, 80's model MF375, 08 2660, 03 5030 and 2010 M8540 and none of them start like that.
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
HD Hayrack Wagon (A50515)
HD Hayrack Wagon...
