New L3901
   / New L3901 #1
Bryan1965
Hilliard, ohio
2016 Kubota L3901
My new used L3901 was delivered, love the tractor however it is so wet here, especially behind the house where we had a septic installed, I got it stuck the first day trying to get it put away,
I wish it had R1 tires, these R4s have hardly any traction in muddy areas,
I will get more pics when I it dries out! C998BABD-E744-414F-8E8B-22DBFE46BDD0.jpeg17EA3A16-D7E2-465A-9845-A97A430A2785.jpegB24CB0C1-4312-460E-9E11-1515C73C37F2.jpeg1FE6B0D1-02C0-4065-9814-7F816072FA6D.jpeg
   / New L3901 #2
Congrats :thumbsup: your bones and muscles will be thanking you in years to come. :)
Yup R4's sure can get greasy real quick,getting stuck just part of owning tractor they say. ;)
   / New L3901 #3
Congrats! Looking good! :thumbsup:
I have the same model with R1's. Have you considered speaking with your dealer? Can't hurt to ask them to switch them out for you. With no hours on the tractor, they would most likely place on another tractor. The R1's are less expensive but you may have to eat the difference for the switch out. You'll have the tractor awhile so any cost might be worth it, and the dealer should want to keep you happy for future maintenance business and positive word of mouth from you.
   / New L3901
Thanks, it actually has 500 hours on it, right now I am waiting for my bonus so I can get the rotary cutter, I have a lot of ground to clear and some paths to start making, I also was moving some dirt yesterday and my son made me stop my back wheels where coming off the ground, one one time my left wheel dug in to soft ground and it felt like it was gonna tip (my property is now wet heavy clay) I need some weight, started pricing weight boxes yesterday, expensive hobby..lol I am supposed to have filled tires, I am sure I do, but still need more weight.
I am also a few weeks away from getting a load of grave, and needing to move that to different parts of property. All this and I am a novice when it comes to tractor operation so have a lot to learn..
Gonna be a great summer :)
   / New L3901 #5
That is SUPER dangerous. The front axle is just a pin & the axle will flop side to side. If the rear comes off the ground its balancing on that front pivot. At that point the tractor is going to flop to one side or the other. It will have enough momentum to keep going over by the time it gets to the stops.
The economy Ls are really light for the loader capacity. The back end of my former L3200 was really light with a couple hundred lbs of stuff stacked on the back of my 5' rotary cutter. I actually think the economy Ls are dangerous with a loader if you don't have loaded rears.
I built some 3 put ballast out of a leaky air compressor tank. Really it's not rocket science, just heavy. I never use it though. Impliments are usually about as heavy & have the benefit of being useful for their intended purpose. A rotary cutter is a bit big & gets in the way in tight spaces. But it's long giving you lots of leverage & you can stack a few bags/bales of something heavy on the back.
   / New L3901 #9
Any tractor user that has stuff in the FEL needs counterweight in the back. A weight box does one task so buy a boxblade or rear blade for weight and for use or even a tiller. I keep one of them on my L3901 all the time. Many tractors in 16 years and never bought or seriously considered buying a weight box myself. A RatchetRake or Piriniha bar is also a great add for the FEL bucket. The RR is best for leveling/landscaping/yard care and the Piriniha is best for digging and small brush/tree clearing or buy both :).
   / New L3901 #10
As much as I love one implement doing two jobs (counter weight being the second). There is something very nice about having 8-900 lbs. up tight close to the back end so you don't have to run it into things... but I would add, make the weight box yourself, no need to buy one. Well, I bought one but it was $50, so I couldn't pass it up!
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
5011 Ford F-550 (A55973)
5011 Ford F-550...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
