new L3800-gear operated 2013-Tier 3
   / new L3800-gear operated 2013-Tier 3 #1
Marine542
Thibodaux,la
YN-2000 1966 Farm All
Hello Guys
I just bought a new L3800-gear operated-Tier 3 with a 61/2' --18x20 disk and will be breaking it in in Mississippi planting food plots. Any recomendations would be appreciated, Any break in requirements, RPM, what gear to use.
Thanks Tim
   / new L3800-gear operated 2013-Tier 3 #2
I have an L3940 which would be somewhat similar and I disc in 1st gear on the high side for the first pass and 2nd gear on subsequent passes. This is in the garden where it has been plowed already.
As for break in - I would just stay away from WOT and try to use the tractor at different engine speeds - not too much bother for the first 50 hours. After that I considered mine 'broken in'.
Enjoy the new tractor!
Keefer
Keefer thanks for the reply. Tim
   / new L3800-gear operated 2013-Tier 3 #4
Your L3800 has three ranges, High range is for transport - depending on how aggressive you set the disk, you'll be looking at med. or even low range for the first pass. The tractor will let you know if you are in the wrong gear ;)
Need to update your tractor profile... Did you get Ag tires?
A geared L3800 only has two ranges High and Low with reverse. I normally use mine in Low-4th for loadering and using the disk because of the torque,speed and high speed you get while in reverse. Only time i use high is while bushogging my pasture if it isnt to thick, or driving long distance.Of course if you have ag tires it will change the ratio a little but should be close to the same as mine.
   / new L3800-gear operated 2013-Tier 3 #5
A geared L3800 only has two ranges High and Low with reverse. ...
Oops, Learned me something new today... :thumbsup: Had no idea that was the case (deleted original post). Thanks.
2004 Ford F-550 4x4 Auto Crane 4004EH Crane Service Truck (A51692)
2004 Ford F-550...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Duetz Power Unit (A50120)
Duetz Power Unit...
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
