Buying Advice New L3800 Did I get it Right?
   / New L3800 Did I get it Right? #31
It might be easier to use the FEL without the toothbar for snow removal or use the heel of the bucket for dragging backwards (smooths out the ground). Also, extend the toplink of the 3ph for dragging the boxblade around, you only want to use the rear blade of the boxblade (unless you need to cut into the gravel). If you use the boxblade to push the snow, be careful, a longer toplink will make the boxblade want to dig into the ground and you might bend the 3 point lower arms.
   / New L3800 Did I get it Right? #32
Hydraulic Toplink
   / New L3800 Did I get it Right? #33
Another very jealous member here ! I'll be doing some serious shopping in the Spring for a L3800 with FEL - and now "have the the bug" more than ever.
I agree with the others - let's see some pics !!!!
   / New L3800 Did I get it Right? #34
I love my new L3800 with FEL. It is a great compact tractor with a lot of power (at least i think it has a lot). I would defiantly recommend it.
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
