New L3400 arrived yesterday!!!
   / New L3400 arrived yesterday!!!
I was looking at the spec sheet that I have in the owners manual. The L3400 has a dry-type dual stage clutch and live continuous running pto. Not a whole lot of difference between the two tractors that I can tell. I will be trenching power and water out to the barn this weekend and I will get to use a friends boxblade to move some dirt back into the trench. Can't wait to play around a bit and get her dirty. Gunman
   / New L3400 arrived yesterday!!! #12
SIR,
in regards to moving the wheels to the widest setting.
i did mine, with some help from my friend, and it was
no big problem. it does help if you have an air compressor,
and a air wrench. i suggest you look at your owners manual,
and see what it says about this. if i remember correctly the
wheels have to be reversed, (right side goes one left side, and
left side goes on right side)
good luck with your projects.
accordionman
william l. brown
wright city, mo.
Thanks for the info on the wheels. I have been looking at them and kinda figured I would have to switch the wheels around, but didn't know for sure. I will see If I can recruit some help soon and try it. Again thanks. Gunman
   / New L3400 arrived yesterday!!! #14
gunman, I had a L3000 DT, same machine, what a sweetheart. I used a Farmi 351P winch for logging, had ag tires loaded but did have a fel and put a large bolder or two in it for steep grades. You should have a weight bar on front and load it with weight to winch logs. You won't believe what the tractor and the Farmi will winch out "incredible". http://www.valby.biz/newpage6.htm good luck and enjoy even though, that goes without saying.
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
John Deere (A50322)
John Deere (A50322)
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
