New L2800hst
/ New L2800hst #1
mattridessleds
Delanson, NY
2010 Kubota L2800 HST, Ji Case 400b
Well finally pulled the trigger today on a new kubota. Was a left over from last year seeing that kubota phased out the L2800. So far so good put about an hour on it today. Got rid of the 1958 case and replaced it with the kubota what a differnece should have done it a long time ago. Just the little things like power steering and brakes make a differnece:thumbsup:. Attached a couple of pics had to get a little mud on the tires of course.
/ New L2800hst #2
Looks good, I noticed you got the newer model of loader the LA524 and with the Quick Atttach bucket. Are those remotes I see on the ROPS?
James K0UA
/ New L2800hst
Good observation. It is the newer loader same as would be on the newer 3200 and 3800 I believe it has about 100lbs more lift force than the older model. I added the remote for a snowplow that I intend to rig up to the loader so I can angle it and also for whatever else comes down the road later as far as attachments.
/ New L2800hst #4
Nice setup. You'll enjoy the heck out of it. :thumbsup:
/ New L2800hst #5
you have a nice looking tractor there.
/ New L2800hst #6
Congratulations on your new tractor.:thumbsup:
/ New L2800hst #7
... It is the newer loader same as would be on the newer 3200 and 3800 I believe it has about 100lbs more lift force than the older model...
I'm pretty sure it's the same lift, but it's measured from a different point, thus the larger number... ;)
/ New L2800hst #8
Congratulations! Good looking tractor.:thumbsup:
/ New L2800hst #9
Good looking machine. Put some weight on the 3pt hitch and then it will really come to life for loader work. You won't be having the light-butt problem.
/ New L2800hst
I have a cement weight box that I used on my old case 400b that I put on the back figure it's around 1000lbs it will lift and move just about anything that I care too move. I'll try to attach the best picture I have so far.
Thanks
Invoices (A65640)
Invoices (A65640)
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2022 EZ-GO ELITE...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
Cattle Feeder (A65640)
