New Kubota
/ New Kubota #1
smoothie17
Virginia
Kubota B2910
I have a B2910 that I've been very happy with. My best friend is now thinking about buying a small tractor which he would use to mow his lawn which is about 1 acre, spread mulch, grade his driveway from time to time and maybe use a backhoe for trenching or moving bushes, etc..
I told him I would buy him a 4' rotary cutter if we would help me mow my 19 acres every now & then.
He's going to look at the BX23 and the B7510. Any suggestions between the two would be helpful and I will pass along to help him decide.
Thanks !!!
/ New Kubota #2
Both seem like a lot of tractor for what he is going to use it for. However, if I had to choose one of the two based on what you said he is going to do, I'd say a BX23. If it where my choice and Kubota was the way I wanted to go it would be more along the lines of a BX1500 w/FEL with a MMM and small box blade. I'd just rent the back hoe for a day to do the trenching.
/ New Kubota #3
This is always a matter of $$$$$. If he can afford the BX23, then that will be the best choice for what you have described. If it comes down to a matter of $$$ then I would suggest that he consider the BX1830. I am not placing any disparaging remarks about the BX1500, however I feel that the BX1830 with the larger engine, tires, and fuel gauge is a better deal. If he wants to go bare bones cost, then there are some other choices out there in other brands, which I am not familiar with. Just seen a lot of them touted on the board in the past. Whenever questions like this come up, there are a lot more variables that need to be stated before a definitive recommendation can be made. You mention the size of the lot, and what he is thinking of doing with the machine. I know that for me, the backhoe is worthwhile, even though it doesn't get the use now that it did 2 years ago. To me, it is like having a car in the driveway that I don't drive very often. Sure a taxi might be less expensive way to go, but it is the convenience that outweighs the costs involved. As long as I can afford to let it sit idle, then I will. When I can't then that luxury will be gone.
/ New Kubota #4
I was going to buy a BX2230 but after researching ground clearance I went with the B7510 which has about 6" more ground clearance. I am using it to clear about 2 acres of woods and with only 6" ground clearance the BX series is just too low for my purposes.
With only 1 acre, and if ground clearance is not an issue, I would think the BX series would be the better choice for your friend.
I would like to have a backhoe but given the price I could not justify the expense. I could use it to dig out stumps but I can get a stump grinder to grind a lot of stumps for 25% of what I would have paid for a backhoe. And if I really need a backhoe I can hire a local guy with his backhoe for about $60 an hour and he can do more in an hour than I could do in 4 or 5 hours since he does it every day.
Bill Tolle
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2022 EZ-GO ELITE...
