New Kubota Model Questions..
/ New Kubota Model Questions.. #21
3 seasons ago i had a snowblowing contract for the sidewalks of a large condo complex. We got slammed with one of our famous new england northeasters and i was in the seat of the B7500 for 30 straight hours! I was warm & dry thankx to the curtis cab but my gludius maximus was hurting bad! A bad seat wrecks the whole experience!
/ New Kubota Model Questions.. #22
I also have memories of many hours in the pan seats on my old 8N and my old 601. That is why, 30 years later, I insist on a good seat on any tractor I use. My memory may be faulty about those pan seats, but I think they may have been more comfortable than some of the Kubota seats I have sat in recently.
/ New Kubota Model Questions.. #23
I just flat out know the 8N seat was better. My Kubota seat is modified to move back far enough to get my legs and feet somewhere close to fitting in the thing, which puts it pretty much in solid contact with the added on ROPS. The rears are loaded, which really stiffened up the impact harshness. For most of my seat time, I feel like I'm sitting on a folded up towel attached to a rock sliding down a rough and bumpy hill.
/ New Kubota Model Questions.. #25
Did you know kubota asks around 900$ for the seat in the L5030 HSTC's? What are they doing with the other 850$? lol!
Actually I don't mind the seat as the last machine we had the seat was tore all to bits. I think they try to sneak a very slim seat in their machines to fit bigger people. The suspension doesn't have much travel either.
Thank-you who ever posted about the loaded tires, I've never driven a tractor without and wondered if it would be more comfy. The dealer loaded mine without me specifying it. I know the big international we also use is a lot more comfy with low pressure 16.9x30 radials and a long wheelbase, and a long travel seat spring.
/ New Kubota Model Questions.. #26
You're welcome slowzuki. I was really surprized when I got my tires loaded at how much the ride deteriorated. Keep in mind I'm running 6 x 15 Ag tires in the rear. I had them filled with windshield washer fluid so it wouldn't eath the rims if I developed a slow leak or bad valve. Even so, my tractor is still pretty tippy when I have a load in the bucket and am headed downhill. Sidehills are an exercise in v-e-r-y s-l-o-w motion, bucket almost on the ground, and keeping a sharp eye for any rocks, roots, or branches more than an inch or two thick on the uphill side. There is essentially no give to the loaded tires, so driving over any obstacle raises the rear by that amount, unlike the unloaded tires, which sort of wrap around a rock or log chunk. With a load hanging out the front and the front axle able to pivot, it gets interesting.
As an experiment just after I got the tires loaded, I put a load of gravel in the bucket, then gingerly angled the thing downhill at about 45 degrees off axis. I had my concrete counterweight hung on the 3 point. With the tractor motionless, I got my 210 lbs. off the seat. Then I pushed against the ROPS from the uphill side and rather easily lifted the uphill rear tire off the ground. Once I had pushed it to the limit of the front axle pivot, I couldn't move it further without a lot of effort, so I guess it just seems a lot spookier than it really is. Still, I would prefer to feel more stable when driving the thing around.
In sum, adding the fluid does 3 things: 1) It makes the tractor heavier lower down and at the outside, supposedly lowering the center of gravity and increasing the polar moment of inertia along the fore/aft axis, thus allowing it to move further from vertical before falling over. 2) It makes the tires much harder, making the tractor tip more when traversing obstacles with one rear tire and not the other one 3) It makes the tractor ride much harder.
A ballast box will add weight and alter the C/G but won't impact the polar moment much because the weight is centered.
Wheel weights will add weight, alter the C/G, alter the polar moment, and not affect ride comfort or the ability of the tires to deflect upon contact with an obstacle.
If I had it to do over again, I'd get weights instead of loading the tires.
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
Iranch IRET13 Electric Tricycle (A64127)
Iranch IRET13...
1985 Rolls-Royce Sedan x14250 (A62613)
1985 Rolls-Royce...
Cattle Feeder (A65640)
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
