New Kubota M6 windshield washer flows back into reservoir
   / New Kubota M6 windshield washer flows back into reservoir #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
My new Kubota M6 front windshield washer drains back into the reservoir. It takes over 30 seconds to get water to the windshield. Dealer tech says they all do it. I have never had a tractor do it. If this is standard I can put a valve in the line but I cannot expect this happens to everyone. Rear window washer is fine. You guys ever seen this on new Kubota's?
   / New Kubota M6 windshield washer flows back into reservoir #2
Just think, you are saving the environment by not letting a drop of toxic washer fluid leave the reservoir.
   / New Kubota M6 windshield washer flows back into reservoir #3
My M9 cab does the same deal. I ignore it and hold the wash function a tad bit longer. Don't bother me at all....
If I did not have to use it often it would not be an issue. Snow blowing for a living makes it see a lot of use. Trying to drive down a road with 6" of snow on it holding down the button for 30 seconds to get nothing is annoying. If this is the norm I will look into a valve to put in the line.
   / New Kubota M6 windshield washer flows back into reservoir #5
Simple answer is install an inline check valve in the washer hose line.... Not an issue with me however. I'm sure you can source one on Amascon.
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2017 UTILITY VS2RA...
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
