New Kubota M6 windshield washer flows back into reservoir
   / New Kubota M6 windshield washer flows back into reservoir #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
My new Kubota M6 front windshield washer drains back into the reservoir. It takes over 30 seconds to get water to the windshield. Dealer tech says they all do it. I have never had a tractor do it. If this is standard I can put a valve in the line but I cannot expect this happens to everyone. Rear window washer is fine. You guys ever seen this on new Kubota's?
   / New Kubota M6 windshield washer flows back into reservoir #2
Just think, you are saving the environment by not letting a drop of toxic washer fluid leave the reservoir.
   / New Kubota M6 windshield washer flows back into reservoir #3
My M9 cab does the same deal. I ignore it and hold the wash function a tad bit longer. Don't bother me at all....
If I did not have to use it often it would not be an issue. Snow blowing for a living makes it see a lot of use. Trying to drive down a road with 6" of snow on it holding down the button for 30 seconds to get nothing is annoying. If this is the norm I will look into a valve to put in the line.
   / New Kubota M6 windshield washer flows back into reservoir #5
Simple answer is install an inline check valve in the washer hose line.... Not an issue with me however. I'm sure you can source one on Amascon.
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
