New Kubota B2650
   / New Kubota B2650 #1
jetdriver
Bracebridge, Ontario
Kubota B2650 Cab
Hi Everyone! I don't post much, sorry! Not even sure if the photo's I attached are going to show because I don't know if I did it properly? Guess we'll find out.
I have a new B2650 and may purchase some pallet forks for her this week!
I am wondering if anyone who owns a B2650 uses it with forks to move around skids of firewood? And the BIG QUESTION: How much can you realistically carry on a skid?
Thank you in advance!
   / New Kubota B2650 #2
I have a Mahindra 1538 which is a 38 HP machine. With pallet forks (not the clamp on the bucket style) I could lift the pallet in your second photo. I think the B series will be right on the edge with that load. With something on the 3pt for counter balance (I like my BB) and some light forks (not everything for a CUT should be heavy duty!) you stand a chance! Good luck!
   / New Kubota B2650 #3
I lift 55 gallons of diesel on a 50# pallet box I built, about 450-500#. I have a everything attachments lightweight 42" pallet forks and a titan ballast box on the back full of bricks and sand. My 2650 lifts the package easily without complaining, but it does rock some. I could use more ballast, like twice as much. The issue you will have is carrying that much weight safely over rough terrain. I'm a safety nut and I won't try much more weight (500#) unless I'm on very level ground and moving slowly. The B series are narrow and the front tires are pretty small and are easy to tip with its robust loader and a heavy load. I think the loader is rated at about 1200#? (The model number is the number of kilos it will lift). Keep your load only high enough the clear the ground. Go ahead and get a set of forks. I use my forks more than any other attachment. It's amazing all the things you will find they can do for you. You will love them.
   / New Kubota B2650 #4
I have a B3300 and I think your loader is rated a little higher capacity. The pallet of wood you pictured would/should be handled without a problem. The Construction attachments lightweight forks skipperbrown referenced in his post are nice and perfect size for your machine. I wound up with two sets! Did you get Kubota's proprietary Q/A or the universal SS Q/A...difference in pricing between the two.
You'll like having set of forks, very handy attachment. No problems with your photos...
   / New Kubota B2650
Sounds pretty awesome! My BX25D was a great machine, but started to feel pretty small and light duty after time went by.
B2650 with heated cab is pretty sweet!
I Have a blower on the back that I haven't used. It has not snowed here since I got it! Un-heard of!
Backhoe to put on in the spring.
The forks sound like a great plan. I will go for it!
I'll start with a half load on the skid and keep testing to get a feel for how much will go with some comfort :)
   / New Kubota B2650 #7
I fretted over 42" forks or 48" and went with 42". After using them a lot, I think the 42" are the cat's meow for this tractor.
   / New Kubota B2650 #8
I have the B26TLB and forks are indispensable. Lift capacity is a realistic 1000lbs or half a pallet of wood pellets....anything more is pushing it. For the lighter B2650 loader I would stay around 800lbs lifting...either way use good judgement and let the tractor decide what is realistic via by what is happening.
   / New Kubota B2650
Great Responses Everyone!
Skipperbrown, I didn't even really think about the length of the forks! Do you think that extra length would come in handy here and there?
I will also be using the forks to position logs better for cutting on occasion. When spring comes and I put my backhoe on for summer, I usually use the backhoe to lift the logs for me for a nice cutting height.
As far as the weight goes with the skid of wood. I guess half to 3/4 of a face cord I'm thinking. A green face cord is somewhere near 1400 lbs I think.
   / New Kubota B2650
Skipperbrown... How much weight do you think your ballast would be? I know my snowblower has a fair amount of weight to it and in summer would be the weight of the backhoe.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
Year: 2004 Make: Kia Model: Optima Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2004 Make...
