kensfarm
Veteran Member
I have seen & read multiple posts regarding 3pt hitch damage.. most seem to be caused by using boxblades in reverse.. hitting a stone or a stump. This problem.. for some reason.. just seemed to stick in my head.. and I been thinking of a low cost.. after market solution. Has anyone ever seen or heard of a top link.. that includes a shear pin devcie? Here's my idea.. a top link w/ the normal functionality of being able to resize by turning.. but a modification to the middle section.. that has the sliding back & forth capability.. much like a PTO shaft.. the modified "sliding section" would then be secured w/ a shear pin in such a fashion.. that when breaking force is applied.. the top link would slide in/together.. or slides out/apart.. The sliding section could be limited.. so that when a breaking force is applied.. it could slide out.. but not apart.
This setup would provide a method to prevent the 3pt hitch from buckeling under extreme stresses caused by hitting a solid object.. the shear pin would give.. and force the implement to slightly rotate/pivot on the lower arms up or back. (similiar to a shear pin protected plow )
What are your thoughts on this device.. if it hasn't already been done.. I'm always looking for a way to retire early. I'm working to put a diagram & prototype together.. (a weldor could probably put this together as fast as I could draw it on paper) the sliding section can be as simple as two pieces of pipe.. one sliding inside the other. I thought this would provide an affordable.. easy.. after market solution.. that would save the 3pt hitch on the implement.. as well as help protect the tractor's rear components.
Looking for input.. idea's of why it would or would not work. Thankyou! Ken Davis
