Taylortractornut
Elite Member
- Joined
- Mar 27, 2002
- Messages
- 2,921
- Location
- Iuka Mississippi USA
- Tractor
- 3550 Fard Backhoe and a 1948 Farmall Cub,
Tatra down south of here in the MS delta the farm land sits on top of Gumbo mud. its super sticky. They \use the rotary ditchers i nthe hevey soil to drain the rice fields in the fall and in spring to plant. This stuff is super sticky you walk around on it and your shoes get thicker and thicker. I made one years ago to clean out a ditch with a little Yanmar a friend had. I used hub and set of tines off a rotovator about 10 inches in diameter and mountd it on a 1 1/4 inch sft like the tiller it came on. I then mouned it on a ste of bearings and put a pulley on the back. It was mounted on a 3x3 tube so that it offset the tractor and we built a 3 point hitch for it. I then adapted a pto shaft to fit another set of bearings with a 12 inch pulley on the back of it and fitted a guard to it. They used to to clean out ditches in gumbo down a 1000 yard road. It wouldnt gum up as it ran fast enough to sling everything out. the guard did have to be removed because it built up on the inside. Later we used a plastic dumptruck liner to coat the shield and it worked great. Look up Alamo ditchers and a few others you ll see some i nsome tough clay. IThe county road deptments here use them for our rural road ditches and can cut iron pipes in half.
